Upgrading a stand-alone application from VB2005 to VB2010, .exe disappears?
1047
05-19-2011 09:37 AM
jihuawang
Hello,
I developed a stand-alone application using VB.net 2005 for GIS9.2 several years ago and the .exe file is generated in my_project\debug and works great.
Now I am upgrading this application using VB.net 2010 to be compatible with Arcgis 10 (with Visual studio 2010) according to the steps showing in this link
http://help.arcgis.com/en/sdk/10.0/arcobjects_net/conceptualhelp/index.html#/How_to_migrate_ArcGIS_9...
I recompiled my project in VB.net 2010 and there are no errors but some warnings(rebuild all succeeded).
My question is
I cannot see any .exe generated in my_project\bin or my_project\obj\debug but some .dll files. Is it normal? I am not sure whether my new project has been successfully rebuild though there is no error message.
How to get a stand-alone application (.exe) like what I got in VB.net2005?
Any suggestions?
Thanks a lot!
NeilClemmons
Honored Contributor
Sounds like you changed the project type from Windows Application to Class Library.  If that's the case then you need to change it back.
jihuawang
Hi, Neil,
Thank you very much! After I change project application type, .exe shows up in my_project\bin. Great!
But I found another problem when I specify the startup project. Do I need to specify one of my window form applicatioin in the startup project? I don't have a sub main in my project.
Also is there any sample ArcScript code written in VB.net 2010 for desktop 10 applicationi? I want to take a look and may find some hints.
Thanks a lot for your help!
