How to assign a classified renderer to a GdbRasterCatalog layer
924
05-19-2011 06:26 AM
ThomasCox
I am trying to assign a classified renderer to a GdbRasterCatalog  layer with no luck.  I have examined the samples that are provided, but have not been able to make it behave.
I have developed code that allows a user to specify a date range, retrieve GRIDS falling within the range, build, and populate a GdbRasterCatalog, and add it to the ArcMap session.  I was hoping the classification renderer assignment would be as straight forward as it is with a standard stand alone raster.
For the portion of the application that retrieves the stand alone GRIDS, it is pretty straight forward to assign an existing renderer derived from a .lyr file that contains the proper renderer classification definition. The GdbRasterCatalog apparently does not offer the option of  assigning a renderer in that fashion.
Through the ArcMap interface, I am able to go through the process of adding the classified renderer type and removing the other non needed rendering types and building the appropriate classified renderer.  I need to be able to do this programmatically through C#.  I understand that the classification renderer is not one of the ???default??? renderers associated with the GDBRasterCatalog layer.
I have examined the IRasterCatalogRendererPicker bit, with no luck.
If need be, I can go through the effort of building the classified renderer directly from the catalog and abandon trying to use the renderer derived from the .lyr file. However, I still need to know how to assign the renderer to the GdbCatalog layer.
Any assistance would be greatly appreciated
NeilClemmons
Honored Contributor
Can you not use IGeoFeatureLayer.Renderer to assign the renderer from the layer file to the layer?
ThomasCox
Thanks for the response.
I have not tried your suggestion.  However, as soon as I finished the post, it occurred to me to build a new array, load it with the desired renderer from the layer file and then assign the renderers property fo the GdbRasterCatalog layer to the array.
                IArray pArray = new ESRI.ArcGIS.esriSystem.Array();
                pArray.Add(pRasterClassify);
                pGdbRasterCatalogLayer.Renderers = pArray;
I appreciate your response. As I refine the the application I may migrate to the approach you suggested.
