Update a field using the values from another table field
4583
12-03-2010 12:04 PM
SanthoshBalakrishnapillai
I have one table and a shape file. I have 2 fields named MUN,CITY in the shapefile. The same fields are there in the table also.
if Shapefile.MUN =Table.MUN then
populate shapefile.CITY with corresponding Table.CITY values.
Anyone have the code please share with me. Thanks in advance.
Venkata_RaoTammineni
hi,
please check below conversation ...might helps you....
http://forums.arcgis.com/threads/17004-Populate-one-field-based-on-another-using-a-lookup-list
Thanks and Regards,
Venkat
Venkat,
Thanks for the reply.
But did not help that much.
hi,
Thanks and Regards,
Venkat
