Union Line
4651
04-09-2010 08:37 AM
TonyAlmeida
MVP Regular Contributor
I have a road center line with thousands of road segments. I would like to union all segments with the same Fename(street name) into just one line feature. Is this possible and if it is how can this be done?
TonyAlmeida
I found the "Merge Feature" but I would like to merge all the lines that have the same FENAME. The "merge Features" just merges the selected feature, is there not a way to merge like this but by attribute field?
http://edndoc.esri.com/arcobjects/9.2/CPP_VB6_VBA_VCPP_Doc/COM_Samples_Docs/Geodatabase/Schema_Creat...
TonyAlmeida
Just letting you know that i used the Dissolve tool for what i needed to do and it worked great.
DavidWasserman
How did you use the Dissolve tool to do this? Did you do an intersection of the lines first?
Yes I realize this is a 5 year old post. 😃 Just curious.
David Wasserman, AICP
