UID is ambiguous in namespace ESRI.ArcGIS.esriSystem
3256
06-30-2010 06:52 AM
CharlieHarper
In VS Express 2008, when I add a dockable window using a template, I am encountering the error "UID is ambiguous in the namespace ESRI.ArcGIS.esriSystem."  This occurs in the following autogenerated routine which is called from the OnClick event:
    Private Sub SetupDockableWindow()
        If m_dockableWindow Is Nothing Then
            Dim dockWindowManager As IDockableWindowManager
            dockWindowManager = CType(m_application, IDockableWindowManager)
            If Not dockWindowManager Is Nothing Then
                Dim windowID As UID = New UIDClass
                windowID.Value = DockableWindowGuid
                m_dockableWindow = dockWindowManager.GetDockableWindow(DockableWindowGuid)
            End If
        End If
    End Sub
End Class
Any ideas on how to fix this namespace issue?
CharlieHarper
I have solved this issue. There was a problem with unnecessary references to the system namespace in my project.
