Truecentroid of a geometry object
1752
05-09-2011 05:55 AM
RolandKantz
I am searching for the TRUECENTROID property of a polyline geometry using c#.NET.
The IGpDescribeGeometry interface seems to have it. Does anybody know how to use it??
Roland
RolandKantz
Has anybody an example, how to use  IGpDescribeGeometry?
Any hints?
Tia
Roland
RolandKantz
Ok, this solution works for me. Calculating the TRUECENTROID (lenght weighted centroid) of a polyline(c#):
public IPoint get_TrueCentroid(IPolyline pLine)
            IPoint pTrueCentroid = new PointClass();
            double pTC_X = 0;
            double pTC_Y = 0;
            ISegmentCollection pSegs = (ISegmentCollection)pLine;
            for (int k = 0; k <= (pSegs.SegmentCount - 1); k++)
                ISegment seg = pSegs.get_Segment(k);
                double length = seg.Length / 2;
                IPoint pFP = seg.FromPoint;
                IPoint pTP = seg.ToPoint;
                pTC_X = ((pFP.X + pTP.X) * length) + pTC_X;
                pTC_Y = ((pFP.Y + pTP.Y) * length) + pTC_Y;
            pTrueCentroid.X = pTC_X / pLine.Length;
            pTrueCentroid.Y = pTC_Y / pLine.Length;
            return pTrueCentroid;
Roland
BerendVeldkamp
What do you mean by the "true centroid", the center of gravity? In that case you could use IGeometry5.CentroidEx(). If you want the midpoint on a polyline (halfway between 'from' and 'to'), use ICurve.QueryPoint(esriSegmentExtension.esriNoExtension, 0.5, true, outPoint).
