I have an Add-In written in VB in Visual Studio 2008. It works just fine, in that environment. I recently upgraded it to Visual Studio 2010 (on a different machine), recompiled and now I get an error at conflictsFound = gdbXmlImport.GenerateNameMapping(gXML, WS, enumNameMapping)
I tried bringing the original compiled Add-In in on the new computer and running it, but it gets the same error (among others). The new computer is running service pack 3, but I think that is the only other difference. Does anyone have any clue as to why it will run on one but not the other?[ATTACH=CONFIG]14409[/ATTACH]Here's all the code: Public Function CreateAccessWorkspace(ByVal Path As String) As IWorkspace
' Instantiate an Access workspace factory and create a personal geodatabase.
' The Create method returns a workspace name object.
Dim gp As IGeoProcessor2 = New GeoProcessor
Dim pParArray As IVariantArray = New ESRI.ArcGIS.esriSystem.VarArray
pParArray.Add(Path)
pParArray.Add(gPGDB)
pParArray.Add("9.2")
gp.AddOutputsToMap = False
gp.OverwriteOutput = True
Dim Result As IGeoProcessorResult2
Result = gp.Execute("CreatePersonalGDB_management", pParArray, Nothing)
Dim WS As IWorkspace
Import_Schema(WS, Path)
End Function
Public Sub Import_Schema(ByRef WS As IWorkspace, path As String)
Try
Dim WSF As IWorkspaceFactory2 = New AccessWorkspaceFactory
MessageBox.Show(Path & gPGDB)
WS = WSF.OpenFromFile(path & gPGDB, 0)
Dim WSE As IWorkspaceEdit2 = WS
' Create a GdbImporter and use it to generate name mappings.
Dim gdbXmlImport As IGdbXmlImport = New GdbImporter()
Dim enumNameMapping As IEnumNameMapping = Nothing
Dim conflictsFound As Boolean
Try
Catch ex As Exception
MessageBox.Show(ex.ToString, ex.Message)
End Try
' Check for conflicts.
Dim workspaceDataset As IDataset = CType(WS, IDataset)
Dim workspaceName As IName = workspaceDataset.FullName
If conflictsFound Then
' Iterate through each name mapping.
enumNameMapping.Reset()
Dim nameMapping As INameMapping = enumNameMapping.Next()
While Not nameMapping Is Nothing
' Resolve the mapping's conflict (if there is one).
If nameMapping.NameConflicts Then
nameMapping.TargetName = nameMapping.GetSuggestedName(workspaceName)
End If
' See if the mapping's children have conflicts.
Dim childEnumNameMapping As IEnumNameMapping = nameMapping.Children
If Not childEnumNameMapping Is Nothing Then
childEnumNameMapping.Reset()
' Iterate through each child mapping.
Dim childNameMapping As INameMapping = childEnumNameMapping.Next()
While Not childNameMapping Is Nothing
If childNameMapping.NameConflicts Then
childNameMapping.TargetName = childNameMapping.GetSuggestedName(workspaceName)
End If
childNameMapping = childEnumNameMapping.Next()
End While
End If
nameMapping = enumNameMapping.Next()
End While
End If
' Import the workspace document, including both schema and data.
gdbXmlImport.ImportWorkspace(gXML, enumNameMapping, WS, False)
workspaceDataset = Nothing
workspaceName = Nothing
gdbXmlImport = Nothing
enumNameMapping = Nothing
End Try
End Sub
