TilePakage tpk
1117
09-01-2012 12:33 AM
konradenzensberger
i am able to create a tile package (tpk) using ArcMap.
If i rename for example test.tpk file to test.zip i am able to extract
the package.
but within the L0-Ln folders i see files like R0000C0000.bundle and R0000C0000.bundlx
how can i extract the png tiles from this files ?
Tpk:
is it possible to create such tile packages using ArcObjects sdk ?
i know the MapCruncher sample, but with IMapCooker it is not possible to set
custom tiling scheme like in ArcMap.
Maybe by using a Geoprocessor tool ? any samples avaliable ?
maybe ArcGIS 10 Toolboxes/Mobile Tools/Create Mobile Map is what i need, but i am afraid, this tool does not
work with mxd files, only ArcServer connection, right?
in general i am looking for a solution to create a map cache using own tiling scheme (openstreetmap) from an Mxd file,
any suggestion welcome,
br, enze
BenoitMetzger
Hi there,
I am having the exact same problem. Have you ever found a solution? I need to be able to retrieve the PNG from the .mpk file!!!
Thanks in advance !
Ben
