The table was not found. [GDB_DBTune] error when creating CreateFeatureDataset
1519
02-02-2012 12:46 AM
DanieliCywyak
Hi
I'm trying to create a FetureDataset. this is my code:
ISpatialReferenceFactory spatialReferenceFactory = new SpatialReferenceEnvironmentClass();
            ISpatialReference fdsSR;
            fdsSR = spatialReferenceFactory.CreateESRISpatialReferenceFromPRJFile(
                "C:\\Users\\user\\AppData\\Local\\VirtualStore\\Program Files\\ArcGIS\\Coordinate Systems\\Projected Coordinate Systems\\National Grids\\ITM_stt.prj");
            IWorkspace wksp;
            string path = "C:\\DC\\Programming\\GIS\\Samples\\MapTable";
            wksp = CreateFileGDB(path, "DataX1");
            IFeatureWorkspace featureWorkspace = (IFeatureWorkspace)wksp;
            featureWorkspace.CreateFeatureDataset("DataX", fdsSR);
when i run it I get this error on the last line:
System.Runtime.InteropServices.COMException was unhandled
  HelpLink="esri_csGeoDatabase.hlp"
  Message="The table was not found. [GDB_DBTune]"
  Source="ESRI GeoDatabase"
  ErrorCode=-2147216882
  StackTrace:
       at ESRI.ArcGIS.Geodatabase.IFeatureWorkspace.CreateFeatureDataset(String Name, ISpatialReference SpatialReference)
       at Map_A_Table.Form1.button1_Click(Object sender, EventArgs e) in C:\DC\Programming\GIS\Samples\MapTable\Map_A_Table\Map_A_Table\Form1.cs:line 409
       at System.Windows.Forms.Control.OnClick(EventArgs e)
       at System.Windows.Forms.Button.OnClick(EventArgs e)
       at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
       at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
       at System.Windows.Forms.Control.WndProc(Message& m)
       at System.Windows.Forms.ButtonBase.WndProc(Message& m)
       at System.Windows.Forms.Button.WndProc(Message& m)
       at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
       at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
       at System.Windows.Forms.NativeWindow.DebuggableCallback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
       at System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg)
       at System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(Int32 dwComponentID, Int32 reason, Int32 pvLoopData)
       at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)
       at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)
       at System.Windows.Forms.Application.Run(Form mainForm)
       at Map_A_Table.Program.Main() in C:\DC\Programming\GIS\Samples\MapTable\Map_A_Table\Map_A_Table\Program.cs:line 23
       at System.AppDomain._nExecuteAssembly(Assembly assembly, String[] args)
       at System.AppDomain.ExecuteAssembly(String assemblyFile, Evidence assemblySecurity, String[] args)
       at Microsoft.VisualStudio.HostingProcess.HostProc.RunUsersAssembly()
       at System.Threading.ThreadHelper.ThreadStart_Context(Object state)
       at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
       at System.Threading.ThreadHelper.ThreadStart()
  InnerException:
Help!!
TimothyOMalley
Was this ever resolved? I have a similar issue.
