Symblize Point Layer
1003
07-29-2013 06:05 PM
shay-geo
All,
I am in a unique situation to symbolize point layer.
For example, I have a point Layer that has following attributes.
Field1, Field2, X, Y, Field3, Field4, Field5
1,1,-71.438467,41.825945,egsq,price rite - eagle square,0,0,0
0,2,-71.438467,41.825945,016495,PRICE RITE EAGLE SQUARE,16495,0,0
0,0,-71.438511,41.826,50
2,0,-71.438041,41.82638,0
I wanted to symbolize based upon Field values with the following criteria.
Field3 = 50 , Then color is Green
Field3 = 0, Then color is blue.
How to achieve this using IUniqueValueRenderer?
I am using following code snippet ...
              #region loop for featurecursor
                while (!(i == n))
                    //System.Threading.Thread.Sleep(1000);
                    IFeature pFeat = default(IFeature);
                    pFeat = pFeatCursor.NextFeature();
                    ISimpleRenderer simpleRender = default(ISimpleRenderer);
                    simpleRender = new SimpleRenderer();
                    IUniqueValueRenderer pRender = default(IUniqueValueRenderer);
                    pRender = new UniqueValueRenderer();
                    pRender.FieldCount = 1;
                    pRender.set_Field(0, "Field1");
                    pRender.FieldDelimiter = ",";
                    pRender.UseDefaultSymbol = false;
                    SimpleMarkerSymbol markerSYmbol = new SimpleMarkerSymbol();
                    IRgbColor color = new RgbColor();
                    int indefOfField = pFeat.Fields.FindField("Field5");
                    int fieldValue = 0;
                    object TPTYpeValue =  pFeat.get_Value(indefOfField);
                    string tpTypeVal = TPTYpeValue.ToString();
                    bool isIntger = int.TryParse(tpTypeVal, out fieldValue);
                    if (isIntger) //Check to see, if it's integer first
                        if (fieldValue == 0) //If value is 0 then assign Red color
                            //markerSYmbol.Color = (IColor)color;
                            markerSYmbol.Color = new RgbColorClass {Red = 255, Green = 0, Blue = 0};
                            markerSYmbol.Style = ESRI.ArcGIS.Display.esriSimpleMarkerStyle.esriSMSCircle;
                            markerSYmbol.Size = 6;
                        else
                            markerSYmbol.Size = 20;
                            markerSYmbol.Color = new RgbColorClass { Red = 0, Green = 0, Blue = 255 };
                    else
                        markerSYmbol.Size = 14;
                    string w = null;
                    w = iRedField + "," + iGreenField + "," + iBlueField;
                    ValFound = false;
                    for (uh = 0; uh <= (pRender.ValueCount - 1); uh++)
                        if (pRender.Value[uh] == w)
                            NoValFound = true;
                            break;
                    if (!ValFound)
                       ESRI.ArcGIS.Display.ISymbol symbol = (ESRI.ArcGIS.Display.ISymbol)markerSYmbol; // Explicit Cast
                        pRender.AddValue(w, "", symbol);
                        pRender.set_Symbol(w, symbol);
                        //Symbolize Feature
                        simpleRender.Symbol = symbol;
                        ESRI.ArcGIS.Carto.IFeatureRenderer _featRender = (ESRI.ArcGIS.Carto.IFeatureRenderer)simpleRender;
                        pLayer.Renderer = _featRender;
                        //_featRender.SymbolByFeature.Draw = symbol;
                        //pLayer.MaximumScale = 3000.00;
                        //pLayer.MinimumScale = 500000.00;
                        #region LabelFeature
                        stdole.IFontDisp font = new stdole.StdFontClass() as stdole.IFontDisp;
                        font.Name = "Times New Roman";
                        font.Bold = false;
                        font.Size = 10;
                        IAnnotateLayerPropertiesCollection _layerAnnotate;
                        _layerAnnotate = pLayer.AnnotationProperties;
                        IElementCollection placedElement = new ElementCollection();
                        IElementCollection unplacedElement = new ElementCollection();
                        IAnnotateLayerProperties _layerAnnotateProps;
                        _layerAnnotate.QueryItem(0, out _layerAnnotateProps, out placedElement, out unplacedElement);
                        //Min / Max Scale for Layer Labels
                        _layerAnnotateProps.AnnotationMaximumScale = 3000.00;
                        _layerAnnotateProps.AnnotationMinimumScale = 500000.00;
                        ILabelEngineLayerProperties pLayerLabelEngineProps;
                          pLayerLabelEngineProps = (ILabelEngineLayerProperties)_layerAnnotateProps;
                        pLayer.DisplayAnnotation = true;
                        #endregion
                    i = i + 1;
                #endregion
                IUID pUID = new UIDClass();
                pUID.Value = "{683C994E-A17B-11D1-8816-080009EC732A}";
                //** This makes the layer properties symbology tab show
                //** show the correct interface.
                IRendererPropertyPage pRPpage = new UniqueValuePropertyPageClass();
                pLayer.RendererPropertyPageClassID = pUID as UIDClass; // pRPpage.ClassID;
                //Add Layer to static list to acces in future
                k++;
                //Release feature cursor
                //Marshal.ReleaseComObject(pFeatCursor);
            #endregion
            //Add Layer to Map
            pMap.AddLayer(pLayer);
            //** Refresh the TOC
            pMxDoc.ActiveView.ContentsChanged();
            pMxDoc.UpdateContents();
            //** Draw the map
            pMxDoc.ActiveView.Refresh();
            #endregion
Thanks and Regards,
Shailesh Gavathe
DavidClarke1
I think this is closer to what you want.  Keep in mind it may not plug into the rest of your code but I hope you get the idea.  I removed the labeling code to make it a shorter example.
//Added for syntax checking
IFeatureCursor pFeatCursor = null;
Int32 i = 0;
Int32 n = 0;
Boolean ValFound;
IGeoFeatureLayer pLayer = null;
IUniqueValueRenderer pRender = new UniqueValueRendererClass();
pRender.set_Field(0, "Field3");
//pFeatCursor = Intialize from your source
while (!(i == n))
    SimpleMarkerSymbol markerSYmbol = new SimpleMarkerSymbolClass();
    IRgbColor color = new RgbColorClass();
    int indefOfField = pFeat.Fields.FindField("Field3");
    int fieldValue = 0;
    if (!isIntger) //if not integer then assume value of 100 for blue
        fieldValue = 100;
        color.Blue = 0;
        color.Green = 0;
        color.Red = 255;
        markerSYmbol.Color = color;
    else if (fieldValue == 50)
        color.Blue = 0;
        color.Green = 255;
        color.Red = 0;
    else
        color.Blue = 255;
        color.Green = 0;
        color.Red = 0;
    ValFound = false;
    string w = fieldValue.ToString(); //0=Red, 50=Green, 100=Blue
    for (Int32 uh = 0; uh < pRender.ValueCount; uh++)
            ValFound = true;
            break;
    if (!ValFound)
        pRender.AddValue(w, null, symbol);
pLayer.Renderer = (IFeatureRenderer)pRender;
