Static layer dissapears when i go into dynamic mode
698
04-29-2011 02:59 PM
BradleyBrown
I'm using vb.net with arc 10.  I create a static ilayer and it displays fine, but when i toggle dynamic mode, my static layer goes away.  if i toggle dynamic mode off, it comes back.  I'm not sure what i'm doing wrong.  It worked fine when i was using 9.3.
Any help appreciated.  Thanks
BradleyBrown
When reading through the sdk concepts for custom layers, i noticed the following comment:
All layers must implement ILayer. For ArcMap to save a custom layer, the IPersistVariant or IPersistStream interface must be implemented. To work with dynamic display, the custom layer must also implement the ILayerExtensions interface.
Is the ILayerExtensions a new requirement for 10?
