SQL Spatial data
3204
07-14-2015 10:17 AM
GéomatiqueSopfeu
Hi Group !
I want to know if I can display SQL spatial data in a vb.net arcObjects application. I have a SQL geography layer that a join to other data to have a final result to display.Everything is done in a stored procedure. The result includes a shape field and a unique renderer is applie must be applied. Is there any way to display SQL spatial in my application ?? Thank you !
FreddieGibson
Honored Contributor
Have you tried adding your data to ArcMap using the Query Layer functionality? I would think that what you'd need to accomplish would be possible via query layers, sql workspace, or plugin data sources.
