Sorting a table using VB.Net
3628
08-04-2010 12:15 PM
DavidKelly1
Does anyone have any sample code that sorts an attribute table?  I am trying to sort an attribute table using a single field.  Below is the code I am using:
        Dim ptableSort As ITableSort
        Dim pQueryFilter As IQueryFilter
        pQueryFilter = New QueryFilter
        ptableSort = New TableSort
        With ptableSort
            .Fields = "stand"
            .Ascending("stand") = True
            .Table = pStdDisplaytable
         End With
         pStandCursor = pStdDisplayTable.SearchDisplayTable(Nothing, False)
         pstdfeature = pStandCursor.NextFeature
David
ThavitinaiduGulivindala
JanDuske
You can trick the QueryFilter instead of using this clumsy tablesort mechanism. (OK, that's not really elegant either, but still better imho):
pQueryFilter.Subfields = "stand";
pQueryFilter.WhereClause = "[your selection criteria]) order by (stand";
The trick is the closing and opening bracket. the first (closing) bracket is the counterpart to an opening bracket created by the ArcObjects parser, which builds a multiversioned SQL query for your where-clause. It builds a huge expression from its managed tables and finally adds a "Where ([yourstring])" at the end. So when you directly use an order by statement, it is pushed into the generated where statement causing an error of course. But if you add the closing bracket after your where clause is complete and afterwards start an order by (or group by or whatever), the generated statement has correct syntax and processes as expected. Just make sure to have an opening bracket in front of the last order by parameter, as a counterpart of the automatically generated closing bracket.
The generated SQL qery for the two code lines above would be like
Select [a huge ammount of columns] from ([an even bigger ammount of joins of uncounted tables]) v_1234 where ([your selection criteria]) order by (stand)
(Your whereclause string red, the automatically added brackets from the ArcObjects parser green)
It works in some combinations for some other methods too, like IQueryDef's, and it does not for FeatureWorkspace.OpenFeatureQuery sadly. Just try it 😉
vincentLahaye
you can't use "Order by" for a Iqueryfilter.whereclause.  you need to use :
IQueryFilterDefinition itfOrderBy = itfYourFilter as IQueryFilterDefinition;
itfOrderBy.PostfixClause = "ORDER BY " + YourField
Vincent
