Simple metadata editor sample
2574
08-06-2010 02:01 AM
ThomasWaenke
I need to automate some metadata editing tasks and used the 'simple metadata editor' sample as an example. In this example the following line updates the Title property.
propertySet.SetProperty("idinfo/citation/citeinfo/title", simpleEditorForm.Title);
With this method only one property/value can be written.
In my case I have some properties that allow multiple values like 2 email addresses under the same property name. How can I do this? I tried an object array as parameter but it did not work.
Thomas
ThomasWaenke
I changed my code and make use of the IXmlPropertySet Interface instead of IPropertySet
IMetadata metadata = (IMetadata)fc;
IPropertySet pset = metadata.Metadata;
IXmlPropertySet psetX = (IXmlPropertySet)metadata.Metadata;
string sValue = "[email protected]";
psetX.SetPropertyX("idinfo/ptcontac/cntinfo/cntemail", sValue,
              sriXmlPropertyType.esriXPTText,
              esriXmlSetPropertyAction.esriXSPAAddDuplicate, false);
metadata.Metadata = (IPropertySet)psetX;
This duplicates the email property in the metadata. But now another problem came up. The following snippet shows a part of the metadata
- <timeperd>
- <timeinfo>
- <mdattim>
- <sngdate>
  <caldate>09.2010</caldate>
  </sngdate>
- <sngdate>
  <caldate>10.2010</caldate>
  </sngdate>
  </mdattim>
  </timeinfo>
  <current>ground condition</current>
  </timeperd>
I need multiple <sngdate><caldate>xxxxxxx</caldate></sngdate> values.
With the method shown in my code and using the "idinfo/timeperd/timeinfo/mdattim/sngdate" property I can duplicate it, but the result are empty <sngdate></sngdate> nodes. When I duplicate the "idinfo/timeperd/timeinfo/mdattim/sngdate/caldate" property I get two <caldate> nodes between the <sngdate> parent nodes which is also wrong.
Is there a way to solve this with the SetPropertyX method?
Thomas
JamesMacKay
ZeljkoVujaklija1
You probably solved your problem by now, but here is solution for someone else.
int counter = 0;
for (int counter=0; counter++; counter<10)
    xmlPropSet.SetPropertyX(""idinfo/timeperd/timeinfo/mdattim/sngdate", "", esriXmlPropertyType.esriXPTText, esriXmlSetPropertyAction.esriXSPAAddDuplicate, false);
    xmlPropSet.SetAttribute(String.Format(""idinfo/timeperd/timeinfo/mdattim/sngdate[{0}]/caldate", counter), "value", "<some date value>", esriXmlSetPropertyAction.esriXSPAAddOrReplace);
