Setting the description of an IStandaloneTable
906
6
06-24-2013 02:23 AM
FrancescoGiovinazzo
From the TOC in ArcMap I can "rightclick -> properties" a standalone table, in the General tab, I can manually set a description.
For a Feature Layer the description can be read and set using the ILayerGeneralProperties.LayerDescription interface and property.
How can I set the description of a Standalone Table using ArcObjects?
I am not able to find a suitable interface to use.
Thanks in advance
Francesco
PeterYurkosky1
This functionality is exposed in the UI, but is not available in the ArcObjects SDK.
PeterYurkosky1
FrancescoGiovinazzo
Thank you for your reply, unfortunately not the one i was hoping for, any plans on exposing it?
Fra
PeterYurkosky1
Sorry, but most new functionality (descriptions were added to standalone tables in 10.0) is not put into ArcObjects by design.
RichardFairhurst
MVP Honored Contributor
That is ominously even worse news than the first.  Is ArcObjects going to be deprecated or downgraded for external users from this point forward?  What is the programming platform game plan going forward?  I certainly need more UI control than I can get through Python or the manual UI.
PeterYurkosky1
No, we're not deprecating ArcObjects. We're just creating new ways to program against ArcGIS. See the "Developers" section of Jack Dangermond's Q&A from last year's user conference:
http://events.esri.com/uc/QandA/index.cfm?ConferenceID=AC1DD535-1422-2418-7F1722E62B9B416A#448
RichardFairhurst
I read the link items.  It does not really explain how a Developer would access the Description of a StandAloneTable, as this thread requested, using any new way to program against ArcGIS.  If it is intentionally excluded from the ArcObject SDK, where else might a Developer discover the new way to program against ArcGIS where he could gain access to control this behavior programatically?  If new functionality will simply not be exposed to the Developer anywhere, the links you provided and your explanation above do not lead me to expect that ESRI would adopt that approach.
