I am one step closer. I am able to access the Dockable Window in my ArcMap application which contains the checkbox that I am wanting to turn on or off from my Add-in, without having to have a reference to the ArcMap application (Add-in)..
While I can now show, reset the caption, move the Dockable Window, I cannot get ahold of the controls within the Dockable Window (textboxes, checkboxes, etc.)
So any ideas as to how I can do this? Or how can I access a public variable within the ArcMap application from the Add-in? I am trying to approach this a different way as well.
Below is the code that is in my Add-in to hook/connect/link to the main application which contains the Dockable Window (FeaturesDockWin is the name of the Dockable Window).
Dim docWinMgr As IDockableWindowManager = CType(My.ArcMap.Application, IDockableWindowManager)
Dim attributeWindow As IDockableWindow
Dim attributeWindowID As UID = New UIDClass()
attributeWindowID.Value = ("MC_GIS10_FeaturesDockWin")
attributeWindow = docWinMgr.GetDockableWindow(attributeWindowID)
The trick to all this is the attributeWindowID.Value which took me a while to figure out. It is the DockableWindow id from the main ArcMap Application I am trying to hook/connect/link to.
Go to the application you are trying to hook/connect/link to (must have a Dockable Window), go to Config.esriaddinx.
There you will find the Dockable Window id, once I plugged it in, onto the next problem!!!!
<DockableWindows>
<DockableWindow id="MC_GIS10_FeaturesDockWin" class="FeaturesDockWin+AddinImpl" caption="Features" image="Images\FeaturesDockWin.png">
<InitialPlacement height="498" width="194" state="pinned" position="left" />
</DockableWindow>
</DockableWindows>
