Set the extent to features on the table of content then export it to jpeg/gif
5059
13
02-03-2012 07:35 AM
OsmanSABAN
Hi all,
I want to export a multiple feature layer by zoom into it then export it as jpeg/gif file then loop through all feature listed on the table of contents. I need to select the feature then zoom into its extent and then export it as jpeg/gif but all the the feature are NTS sheets so all the other features has to be unselected when exporting one of them as jpeg/gif. And then unselect the one just exported then move to next one, select, zoom, export, unselect, etc for rest of the list.
I found below code online from http://www.cartotalk.com. what it does is that select each record in polygon attribute table, zoom to the extent of that polygon, then export the layout to a jpeg at whatever res you want. Then it moves on the next one.
I dont want to zoom into each features attribute table, I want to zoom into whole feature itself extent.
Please help me about this,
Thank you.
Option Explicit
Private m_pMxDoc As IMxDocument
Private m_pPageLayout As IPageLayout
Private m_pGContainer As IGraphicsContainer
Private Sub AddElement(AnElement As IElement, PagePosition As IGeometry)
    Set m_pMxDoc = ThisDocument
    Set m_pPageLayout = m_pMxDoc.PageLayout
    AnElement.geometry = PagePosition
    Set m_pGContainer = m_pPageLayout
    m_pGContainer.AddElement AnElement, 0
    m_pMxDoc.ActiveView.Refresh
End Sub
Public Sub DeleteElement(AnElement As IElement, PagePosition As IGeometry)
    m_pGContainer.DeleteElement AnElement
End Sub
Public Sub ExportLayout(Format As String, FileName As String, dpi As Integer)
    Dim pMxDoc As IMxDocument
    Set pMxDoc = ThisDocument
    Dim pLayout As IActiveView
    Set pLayout = pMxDoc.PageLayout
    Dim rectOut As tagRECT
    rectOut = pLayout.exportFrame
    Dim pEnv As IEnvelope
    Set pEnv = New envelope
    pEnv.PutCoords rectOut.Left, rectOut.Top, rectOut.Right, rectOut.bottom
    Dim pExporter As IExporter
    If Format = "GIF" Then
        Set pExporter = New JpegExporter
    Else
        Set pExporter = New PDFExporter
    End If
    pExporter.ExportFileName = FileName
    pExporter.PixelBounds = pEnv
    pExporter.Resolution = dpi
    'Recalc the export frame to handle the increased number of pixels
    Set pEnv = pExporter.PixelBounds
    Dim xMin As Double, yMin As Double
    Dim xMax As Double, yMax As Double
    pEnv.QueryCoords xMin, yMin, xMax, yMax
    rectOut.Left = xMin
    rectOut.Top = yMin
    rectOut.Right = xMax
    rectOut.bottom = yMax
    'Do the export
    Dim hdc As Long
    hdc = pExporter.StartExporting
    pLayout.Output hdc, dpi, rectOut, Nothing, Nothing
    pExporter.FinishExporting
    'MsgBox "Export complete!", vbInformation
End Sub
Public Sub PanZoomTitleExportWatersheds()
    Dim strImageName As String
    Dim pMap As IMap
    Set pMap = pMxDoc.FocusMap
    Dim pPageLayout As IPageLayout
    Set pPageLayout = pMxDoc.PageLayout
    Dim pActiveView As IActiveView
    Set pActiveView = pMxDoc.FocusMap   ' Set to FocusMap, allows zoom to work in page layout or data view
    Dim pFeatureLayer As IFeatureLayer
    Set pFeatureLayer = pMap.layer(0)   ' First layer in map
    Dim pFeatureClass As IFeatureClass
    Set pFeatureClass = pFeatureLayer.featureClass
    Dim pFeatureCursor As IFeatureCursor
    Set pFeatureCursor = pFeatureClass.Search(Nothing, False)   ' Set QF to Nothing, get all features
    Dim pFeature As IFeature
    Dim Counter As Integer
    Dim pEnvelope As IEnvelope
    Dim pLayer As IFeatureLayer
    Set pFeature = pFeatureCursor.NextFeature  ' clear it, get the first feature
    Do Until pFeature Is Nothing
        Counter = Counter + 1
        ' Create image file name from attributes
        strImageName = ReplaceMultiple(pFeature.Value(5), "_", " ", ",", "-", ".") & "_" & pFeature.Value(9) 'ReplaceMultiple gets rid of spaces/special characters in names
        ' Zoom
        pActiveView.Extent = pFeature.Shape.envelope
        ' Set the extent to that of the active view
        Set pEnvelope = pActiveView.Extent
            ' Expand out a little bit
            If (pFeature.Shape.envelope.width / pFeature.Shape.envelope.height) < 0.3 Then
                pEnvelope.Expand 2, 2, True
            Else
                pEnvelope.Expand 1.25, 1.25, True
            End If
        ' Center
        pActiveView.Extent = pEnvelope
        ' Refresh after zoom
        pActiveView.Refresh
        'MsgBox strImageName
        ' Call ExportLayout, export the current layout
        ExportLayout "GIF", "C:\Users\osaban\Desktop\Datasets-In Process\Canada Land Inventory (150 000) - Land Capability for Agriculture\Alberta\" & strImageName & ".gif", 175
        ' Refresh after deletion
        pActiveView.Refresh
        ' Go to next
    Loop
End Sub
Public Function ReplaceMultiple(ByVal OrigString As String, _
     ByVal ReplaceString As String, ParamArray FindChars()) _
     As String
    'PURPOSE: Replaces multiple substrings in a string with the
    'character or string specified by ReplaceString
    'PARAMETERS: OrigString -- The string to replace characters in
    '            ReplaceString -- The replacement string
    '            FindChars -- comma-delimited list of
    '                 strings to replace with ReplaceString
    'RETURNS:    The String with all instances of all the strings
    '            in FindChars replaced with Replace String
    'EXAMPLE:    s= ReplaceMultiple("H;*()ello", "", ";", ",", "*", "(", ")") -
                 'Returns Hello
    'CAUTIONS:   'Overlap Between Characters in ReplaceString and
    '             FindChars Will cause this function to behave
    '             incorrectly unless you are careful about the
    '             order of strings in FindChars
    Dim lLBound As Long
    Dim lUBound As Long
    Dim lCtr As Long
    Dim sAns As String
    lLBound = LBound(FindChars)
    lUBound = UBound(FindChars)
    sAns = OrigString
    For lCtr = lLBound To lUBound
        sAns = Replace(sAns, CStr(FindChars(lCtr)), ReplaceString)
    ReplaceMultiple = sAns
End Function
Public Function MakeGifFileName(strHucName As String, strHucNumber As String) As String
    If Trim(strHucName) = "" Then
        MakeGifFileName = Trim(strHucNumber)
    Else
        MakeGifFileName = Trim(strHucNumber) & "_" & ReplaceMultiple(ReplaceMultiple(strHucName, "_", " ", "-"), "", "'", ".", ",")
    End If
End Function
KenBuja
MVP Esteemed Contributor
Most of it will go over directly. You'll have to add in "Set" to some of the statements and you won't need the fully qualified declarations (Dim activeView As IActiveView instead of Dim activeView As ESRI.ArcGIS.Carto.IActiveView, for example).
OsmanSABAN
Thank you again Ken,
I made some changes you mentioned and add some Public sub to setup the path to save the gif files and it works perfectly.
Now, another thing is that how can I do the same thing for spatial image files?
Any help?
Thank you
Private Sub ExportToGIF()
            Dim pRaster As IRaster
            Dim pMap As IMap
            Set pActiveView = pMxDoc.activeView
            Dim pExtent As IEnvelope
            Set pExtent = pActiveView.extent
            Dim pEnumLayer As IEnumLayer
            Set pEnumLayer = pMap.Layers
            pEnumLayer.Reset
            Dim pLayer As ILayer
            Set pLayer = pEnumLayer.Next
            Do While Not (pLayer Is Nothing)
                pLayer.Visible = False
            Loop
            pEnumLayer.Reset
                If TypeOf pLayer Is IFeatureLayer Then
                    pLayer.Visible = True
                    pActiveView.extent = pLayer.AreaOfInterest
                    pActiveView.Refresh
                    ExportLayout "GIF", "C:\Users\Desktop\" & pLayer.Name & ".gif", 175
                    'System.Windows.Forms.MessageBox.Show (pLayer.Name)
                End If
            Loop
            pEnumLayer.Reset
            Loop
            Set pExtent = pActiveView.extent '= pExtent
            pActiveView.Refresh
End Sub
    rectOut = pLayout.ExportFrame
    Set pEnv = New Envelope
    Else
    End If
    rectOut.Left = xMin
    rectOut.Top = yMin
    'Do the export
    Dim hDC As Long
    hDC = pExporter.StartExporting
    pLayout.Output hDC, dpi, rectOut, Nothing, Nothing
End Sub
KenBuja
You'd just have to comment out where it checks if the layer is a Feature Layer
Do While Not (pLayer Is Nothing)   'If TypeOf pLayer Is IFeatureLayer Then   pLayer.Visible = True   pActiveView.extent = pLayer.AreaOfInterest   pActiveView.Refresh   ExportLayout "GIF", "C:\Users\Desktop\" & pLayer.Name & ".gif", 175   'System.Windows.Forms.MessageBox.Show (pLayer.Name)                        pLayer.Visible = False   'End If                    Set pLayer = pEnumLayer.Next Loop
Don't forget to mark the answer as correct and/or helpful
OsmanSABAN
Thank you Ken, I did mark it.
I am really appreciated with your help a lot.
Thank you again
