Set Expression to DisplayField
1394
12-23-2010 12:28 AM
karinweixler
Hello,
i am trying to migrate VB.net Code from AG 9.3 to AG 10.
In AG 9.3 this Code worked for setting the label options for the DisplayField of a FeatueLayer (it was set as the label field for the labels):
aoiFeatureLayer.DisplayField = "w_Dat_Flurstueck.FlurNr] & ""/"" & [w_Dat_Flurstueck.FlurNr2"
In AG 10 this code is not working anymore.
I found this new Way to set an expression to the DisplayField:
Dim pDEP As IDisplayExpressionProperties
Dim pIDS As IDisplayString
pIDS = aoiFeatureLayer
pDEP = pIDS.ExpressionProperties
pDEP.Expression = "[w_Dat_Flurstueck.FlurNr] & ""/"" & [w_Dat_Flurstueck.FlurNr2]"
The Problem i am having, is that the exrpession for the layer is only set to the (new) Display Field in the Display Tab in the properties of the layer but not to the Label Field in the Labels Tab. Here is still the standard Field as Label Field.
Is there a different way to set the Label Field for the Labels?
Thanks for helping.
Karin
VivekPrasad
Hello,
Thanks for helping.
Karin
Please try the below sample code
Sub LabelingFeatures(ByVal pLayer As ILayer, ByVal strFName1 As String, ByVal strFName2 As String)
        Dim pGeoLayer As IGeoFeatureLayer
        Set pGeoLayer = pLayer
        Dim pAnnoLayerPropsColl As IAnnotateLayerPropertiesCollection
        Set pAnnoLayerPropsColl = pGeoLayer.AnnotationProperties
        Dim pAnnoLayerProps As IAnnotateLayerProperties
        pAnnoLayerPropsColl.Clear
        Dim pBOLayerProps As IBasicOverposterLayerProperties
        Set pBOLayerProps = New BasicOverposterLayerProperties
        pBOLayerProps.FeatureType = esriBasicOverposterFeatureType.esriOverposterPolygon
        pBOLayerProps.NumLabelsOption = esriBasicNumLabelsOption.esriOneLabelPerShape
        pBOLayerProps.FeatureWeight = esriBasicOverposterWeight.esriNoWeight
        pBOLayerProps.LabelWeight = esriBasicOverposterWeight.esriLowWeight
        Dim tSym As ITextSymbol
        Set tSym = New TextSymbol
        Dim font As IFontDisp
        Set font = tSym.font
        font.Bold = False
        font.size = 6
        tSym.font = font
        Dim aLELayerProps As ILabelEngineLayerProperties
        Set aLELayerProps = New LabelEngineLayerProperties
        aLELayerProps.Expression = "[" & strFName1 & "]" & ""/"" & "[" & strFName2 & "]"
        Set aLELayerProps.Symbol = tSym
        Set aLELayerProps.BasicOverposterLayerProperties = pBOLayerProps
        Set pAnnoLayerProps = aLELayerProps
        pAnnoLayerProps.Class = "<any Name>"
        'pAnnoLayerProps.WhereClause = pSqlString 'You can filter features by using this statement
        pAnnoLayerPropsColl.Add pAnnoLayerProps
        pGeoLayer.DisplayAnnotation = True
End Sub
karinweixler
Thanks a lot! This works just fine!
VivekPrasad
Thank you! Glad to know that the code helped.
