SelectByLocation does not work...
862
05-22-2012 05:41 PM
InsuHong1
I used SelectByLocation geoprocessing object in c#.
                selByLocation.in_layer = lyConvexLine;
                selByLocation.select_features = lyConevex;
                selByLocation.overlap_type = "INTERSECT";
                gp.Execute(selByLocation, null);
                selByLocation.select_features = lyPairLine;
                selByLocation.overlap_type = "WITHIN";
                selByLocation.selection_type = "REMOVE_FROM_SELECTION";
above code worked well. However, in other part of same code, SelectByLocation did not work at all.
                selByLocation.in_layer = lySelectedPoints;
                selByLocation.select_features = lyTempPair;
                selByLocation.overlap_type = "ARE_IDENTICAL_TO";
After above part, nothing happend. I checked number of selected object by GetCount, and even CopyFeature tool, but nothing was selected.
THe only difference 1st and 2nd code is: at 1st code, layers were polygon and line, at 2nd all of two layers were points. But SelectByLocation meant to be worked well with point as well, right?
I test other overlap_types... all of them failed.
My features are not broken. I checked those features inputted to selectByLocation manually.
