Return custom object in Server Object Extension (SOE)
2709
02-03-2014 05:35 AM
CarlTremblay
Hello all,
           Can someone show me the way to expose a custom object (for example a list of enterprise) in a Server Object Extension please.
Thank you very much.
siyufan
Here is the way in SOAP SOE:
1. Create a custom class, need to inherit from IXMLSerialize
using System.Runtime.Serialization;
public class CustomOutputInfo : IXMLSerialize
eg:http://help.arcgis.com/en/sdk/10.0/arcobjects_net/conceptualhelp/index.html#/Sample_Find_near_featur...
2. Add the custom type in to the WSDL.
<xs:complexType name="CustomLayerInfo">
  <xs:sequence>
    <xs:element name="Name" type="xs:string" />
    <xs:element name="ID" type="xs:int" />
    <xs:element name="Extent" type="Envelope" />
  </xs:sequence>
</xs:complexType>
3. Then you can return object using this type.
respMsg.Parameters.AddObject("ReturnResult", customOutputInfo);
RichardWatson
ESRI has a number of samples for this with come with the SDK:
C:\Program Files (x86)\ArcGIS\DeveloperKit10.2\Samples\ArcObjectsNet\*SOE
CarlTremblay
Thank you very much guys ...
