replicate select by location
1179
09-17-2013 06:43 PM
ArthurAmora
I have a polygon shapefile containing several land parcels. I would like to identify which of these parcels would intersect to my other polygon shapefile by creating a single button. Steps on customization are mostly understood by me. But since I'm new to programming, its difficult for me to create the VBA code for this. Any suggestion??
A already constructed code would be very much appreciated. Thanks!
sameerpuppal
You can use Iquerybylayer interface for doing this...
you can also go through some of the forums like :- http://forums.esri.com/Thread.asp?c=93&f=993&t=160044
    pQueryByLayer = new QueryByLayerClass();
                pQueryByLayer.FromLayer = pFeatureLayer;
                pQueryByLayer.ByLayer = pFeatureLayer;
                pQueryByLayer.UseSelectedFeatures = true;
                pQueryByLayer.LayerSelectionMethod = esriLayerSelectionMethod.esriLayerSelectBoundaryTouches;
                IFeatureSelection pFr = pFeatureLayer as IFeatureSelection;
                pFr.SelectionSet = pQueryByLayer.Select();
here from and by layer have been given the same featurelayer you can change it according to you.
