Replace Addin AssemblyCache to GlobalAssemblyCache
1240
09-06-2023 06:39 AM
DharmaRajan
Multiple addins are having few common dll files as reference. So during execution time, under AssemblyCache, Multiple folders, one for each addin(with the same common dll) is maintained  which consumes more memory. Is there any option to copy the supporting dll in GAC path and make the addin to refer the folder?
Currently what we have is:
C:\Users\<username>\AppData\Local\ESRI\Desktop<version>\AssemblyCache \xxxx\commonReferenced.dll
C:\Users\<username>\AppData\Local\ESRI\Desktop<version>\AssemblyCache \yyyy\commonReferenced.dll
Expected output is(something like) given below: (instead duplicating the dll in multiple folder, the GAC folder should be used.) How to achieve this in addins?
C:\Windows\Microsoft.NET\assembly\GAC_MSIL\commonReferenced.dll
GKmieliauskas
commonReferenced.dll must be signed if you want to add it to GAC. More info about placing library to GAC is here.
After your library is in GAC, you need to delete old library reference, then add new library reference from GAC. "Copy local" set to false.
