Rename Feature Class attribute
2915
11-19-2013 09:47 AM
Marc-OlivierEthier
Can I rename a feature class attribute with ArcObjects (FGDB, SDE) ? I'm using IClassSchemaEdit4.AlterFieldName and it seem to work in a FGDB.
I'm asking the question because I have often read that I can't rename a feature class attribute with ArcObjects...
Thanks
RobertBorchert
Honored Contributor
if you only need to do it once don't over complicate it.
just create the new attribute with the name you want and then populate it with the attributes from the old attribute.
Or if your careful simply rename it in Access.
Thanks
LanceShipman
At ArcGIS 10.1 you can use ArcObjects to rename a field in a geodatabase. It was not possible prior to 10.1.
LuisBautista
