Raster draw order?
3038
09-21-2015 08:45 AM
JoeMcCollum
I've got two different raster layers in different frames.  The frames are at different scales.
It doesn't seem to matter whether the one raster is listed first or second - it always draws on top.
But I'd like to put it on the bottom - of course do this programmatically.
I've fooled around with things like this:
          If pAV.IsMapActivated Then
            pDoc.ActiveView = aMap
            pGC.AddElement(qMapElement, 1)
            pGC.AddElement(pMapElement, 3)
        Else
            pAV.GraphicsContainer.AddElement(qMapElement, 1)
            pAV.GraphicsContainer.AddElement(pMapElement, 3)
        End If
But they don't seem to help.....
JoeMcCollum
This sort of works....I think I'm on the right track....
        Dim pApp As IApplication = My.ArcMap.Application
        Dim pDoc As IMxDocument = My.ArcMap.Document
        Dim pGC As IGraphicsContainer = pDoc.PageLayout
        Dim pMaps As IMaps = pDoc.Maps
        Dim gcs As IGraphicsContainerSelect = pGC
        pGC.Reset()
        Dim pelt As IElement
        pelt = pGC.Next
        Dim pEltProp As IElementProperties
        Do While Not pelt Is Nothing
            pEltProp = pelt
            MsgBox(pEltProp.Name)
            If pEltProp.Name = "Inset" Then
                gcs.SelectElement(pelt)
                pGC.SendToBack(gcs.SelectedElements)
            End If
            pelt = pGC.Next
        Loop
        pDoc.ActiveView.Refresh()
        pDoc.UpdateContents()
        MsgBox("Done")
