'QueryFilter' is an interface type and cannot be used as an expression.
366
10-30-2017 12:34 PM
JoseSanchez
Hello everyone,
I am running a VB.net console application in VS 2015 pointing to an SDE SQL Database in ArcSDE 10.4.
I am getting the following error message when creating queryFilter. and featurescount does not have any value. This code works fine in 10.2 and VS 2012 pointing to SDE 10.2 Oracle.
' Create the query filter.
Dim queryFilter As IQueryFilter
queryFilter = New QueryFilterClass()
' Select the fields to be returned
queryFilter.SubFields = "INCID"
queryFilter.WhereClause = "INCID = " & strContentID
queryFilter.WhereClause = "INCID = 10772"
Dim featuresCount As Integer = 0
featuresCount = pFeatureClass.FeatureCount(queryFilter)
' feature count = 0, not found, then create feature
' feature count > 1, check if the version matches
If featuresCount = 0 Then
