Proper use of IEditor (StartOperation / StopOperation)
3244
03-16-2011 09:47 AM
RiverTaig1
I'm having some problems getting IEditor to behave in a stable manner.  If everything goes right in my code, then all is good, but if something unexpected happens (e.g. try to put too much data into a small field) it screws up the editor operation stack (I think) and then I basically need to restart ArcMap. It seems like I might get errors when I call Store, StartOperation, or even StopOperation. It kinda seems to vary. QUESTION: How can I rewrite the code below to keep things in a good state if something unexpected happens? Is there some key method like IsInEditOperation that I am missing as part of good defensive coding techniques.
Essentially my code looks like this:
bool hadToStartEditing = false;
if(editor.EditState == esriStateNotEditing)
  editor.StartEditing();
  hadToStartEditing = true;
editor.StartOperation();
//...More code to create a new feature & set it's shape / subype
// ...More code to set values on various fields (hopefully legal values, but perhaps not always)
editor.StopOperation();
if(hadToStartEditing)
  editor.StopEditing(True);
SteveFang
Try a "Try Catch" block to catch exception.  I like to also use a boolean variable to let me know if I am in an edit operation or not.  That way if my "Try Catch" encounters an exception then I can decided how to clean up the edit.  Ususally involves stopping the edit operation and not saving any changes.
nikhilsastikar
Apart from Try Catch.. Finally block should also be implemented where in case of failure you can stop edit operation and edits.
Thanks
Nikhil
AlexanderGray
Honored Contributor
I always do the try catch block as a matter of fact for every edit operation, I usually call abort operation in the catch block regardless of the error.  This way in the case of any unforeseen error, I stop the operation without messing up the call stack.  Any foreseen error, you are better off handling before it raises an error.  I never use abort operation in event listeners raised inside the operation, for that I just throw my own exception and the esri framework aborts the operation and pops up a message.
