Project to Lat/Long for Google maps using arcobjects
2875
10-08-2014 01:05 PM
JohnBerg
I'm trying to take a coordinate and convert it to Lat/Long for google maps but I don't know enough about projections to handle this.   I know it should be something like this but not sure what my Geo Types should ge or what the SetFalseOriginAndUnits is used for - can someone point me in the right direction?  I'm guessing I don't have the coordinate types correct or I need to project the coordinate somehow.
                ISpatialReferenceFactory srFactory = new SpatialReferenceEnvironmentClass();
                //GCS to project from
                int geoType = (int)esriSRGeoCSType.esriSRGeoCS_NAD1983;
                var gcs = srFactory.CreateGeographicCoordinateSystem(geoType);
                ISpatialReference sr1 = gcs;
                // what should this be???
                //sr1.SetFalseOriginAndUnits(-180, -90, 1000000);
                //Projected Coordinate System to project into
                int geoType2 = (int)esriSRProjCSType.esriSRProjCS_NAD1983N_AmericaLambert;
                var pcs = srFactory.CreateProjectedCoordinateSystem(geoType2);
                //pcs.SetFalseOriginAndUnits(0, 0, 1000);
                ISpatialReference sr2 = pcs;
                //Point to project
                var point = new PointClass() as IPoint;
                 point.PutCoords(2396130.0831298800, 15867438.6259155000);
                //Geometry Interface to do actual project
                var geometry = point;
                geometry.SpatialReference = sr1;
                geometry.Project(sr2);
                point = geometry;
                double latitude;
                double longitude;
                point.QueryCoords(out latitude, out longitude);
My map layer has this info:
                NAD83 UTM, Zone 18 North, US Foot
                Authority: Custom
                Projection: Transverse_Mercator
                false_easting: 1640416.614993545
                false_northing: 0.0
                central_meridian: -75.0
                scale_factor: 0.9996
                latitude_of_origin: 0.0
                Linear Unit: Foot_US (0.3048006096012192)
                Geographic Coordinate System: North_American_Datum_1983
                Angular Unit: Degree (0.0174532925199433)
                Prime Meridian: Greenwich (0.0)
                Datum: D_North_American_1983
                  Spheroid: Geodetic_Reference_System_of_1980
                    Semimajor Axis: 6378137.0
                    Semiminor Axis: 6356752.31414035
                    Inverse Flattening: 298.2572221009113
Tags (1)
RiyasDeen
Hi John,
  1. Your coordinates seem to be projected coordinates but your are assigning a geographic coordinates system in this line geometry.SpatialReference = sr1; You should assign a projected coordinate system for this coordinates (esriSRProjCS_NAD1983UTM_18N in your case)
  2. Geographic coordinates are latitude (valid values -90 to +90) and longitude (valid values are -180 to +180), projected coordiates are generally in linear units meter or miles.
  3. Google maps coordinates are in WGS84 you should project your geometry to esriSRGeoCS_WGS1984
