Programmatically tell if a polygon is a parallelogram
1447
04-09-2012 10:44 AM
DanielLaidlaw
How can I programmatically tell if a polygon feature is a parallelogram??
Appreciate the help
vb
MaraStoica1
Get the vertices, calculate the length of each side and then check that the opposite sides are equal.
BrianBottoms
Below is one possibility. The console app code could use some cleanup (it's even a little hard for me to follow and I wrote it). However, it does work.
The code basically runs around the polygon from vertex to vertex to find the 4 straight lines regardless of how many vertices make the line. It then checks opposite side lengths. If all is well then IsParallelogram returns true.
You can�??t just get the vertices and check the sides because I can digitize a parallelogram with 20 vertices, for example digitize a square then right click and insert an extra vertex - it's still a parallelogram. Also, if you just looked at the vertices you might miss that the vertices are actually connected with a Bezier curve or some type of arc. I'm not sure if I accounted for everything, but I did digitize a bunch of shapes and it returned the correct answer.
Brian
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using ESRI.ArcGIS.Geometry;
using ESRI.ArcGIS.Geodatabase;
using ESRI.ArcGIS.DataSourcesGDB;
using System.Collections;
namespace TestParallelogram
    class Program
        static void Main(string[] args)
            //Get license.
            ESRI.ArcGIS.RuntimeManager.BindLicense(ESRI.ArcGIS.ProductCode.EngineOrDesktop);
            //Get workspace.
            IWorkspaceFactory wsfact = new FileGDBWorkspaceFactoryClass();
            IFeatureWorkspace featws = (IFeatureWorkspace)wsfact.OpenFromFile("C:\\temp\\Shapes.gdb", 0);
            //Get polygon layer and loop features testing for parallelogram.
            IFeatureClass fc = featws.OpenFeatureClass("Shapes");
            IFeatureCursor fcursor = fc.Search(null, false);
            IFeature feat = fcursor.NextFeature();
            Console.WriteLine("Press any key to continue...");
            Console.WriteLine();
            Console.WriteLine("Is feature a parallelogram true/false?");
            while (feat != null)
                Console.WriteLine("Feature OID = " + feat.OID + " " + IsParallelogram((IPolygon)feat.Shape));
            Console.ReadKey();
        private static bool IsParallelogram(IPolygon pPoly)
            bool passesTest = true;
            pPoly.SimplifyPreserveFromTo();
            //Check for arcs/bezier type curves in the polygon.
            ISegmentCollection segmentCollection = (ISegmentCollection)pPoly;
            for (int x = 0; x <= segmentCollection.SegmentCount - 1; x++)
                if (segmentCollection.get_Segment(x).GeometryType != esriGeometryType.esriGeometryLine)
                    passesTest = false;
            //If no curves found keep going
            if (passesTest == true)
                Double pi = Math.Round(3.14159250439667, 4);
                //al holds straight segments of poly i.e. vertex to vertex
                ArrayList al = new ArrayList();
                //alFinal holds final 4 segments of poly after removing vertices that
                //don't create an angle i.e. a straight line with a vertex in the middle.
                ArrayList alFinal = new ArrayList();
                //create lines from vertex to vertex around polygon.
                IPointCollection ptcol = (IPointCollection)pPoly;
                ILine pLine;
                for (int x = 1; x != ptcol.PointCount; x++)
                    pLine = new LineClass();
                    pLine.PutCoords(ptcol.get_Point(x - 1), ptcol.get_Point(x));
                    al.Add(pLine);
                //Try to account for 4 straight lines around polygon.
                ILine line1;
                ILine line2;
                if (al.Count >= 4)//If less than 4 then it is a circle, ellipse or possibly a triangle.
                    GeometryEnvironment geometryEnvironment = new GeometryEnvironment();
                    IConstructAngle constructAngle = geometryEnvironment as IConstructAngle;
                    ILine straightLine;
                    line1 = (ILine)al[0];
                    line2 = (ILine)al[1];
                    int n = 1;
                    while (n < al.Count)
                        //Console.WriteLine(constructAngle.ConstructThreePoint(line1.FromPoint, line2.FromPoint, line2.ToPoint));
                        //Check if angle changes between 2 segments going around the poly.
                        if (Math.Abs(Math.Round(constructAngle.ConstructThreePoint(line1.FromPoint, line2.FromPoint, line2.ToPoint), 4)) == Math.Abs(pi))
                            //No change in angle so vertex splits poly edge, but
                            //line doesn't change direction - go to next segment.
                            n++;
                            line2 = (ILine)al;
                        else
                            //Line changes direction so add segment to final line group.
                            straightLine = new LineClass();
                            straightLine.PutCoords(line1.FromPoint, line2.FromPoint);
                            alFinal.Add(straightLine);
                            //Increment n for next set of lines
                            line1 = line2;
                            n++;
                            if (n == al.Count)//Reached last line segment in poly so just add to final group.
                                straightLine.PutCoords(line2.ToPoint, line2.FromPoint);
                            else
                                line2 = (ILine)al; //Go to next segment in poly
                else //less than 4 segments not enough segments to make a parallelogram.
                    passesTest = false;
                //Check that you have 4 straight lines.
                if (alFinal.Count == 4)
                    //Check that opposite sides are equal length.
                    //I'm rounding because if you digitize a rectangle their opposite lengths don't actually match!
                    line1 = (ILine)alFinal[0];
                    line2 = (ILine)alFinal[2];
                    if (Math.Round(line1.Length, 1) != Math.Round(line2.Length, 1)) passesTest = false;
                    line1 = (ILine)alFinal[1];
                    line2 = (ILine)alFinal[3];
                else //Too many polygon edges.
                    passesTest = false;
            return passesTest;
DuncanHornby
MVP Notable Contributor
You could always use the Parallelogram law disussed in wikipedia here?
