Programmatically change the datasource of a join (IRelQuery DestinationTable ??)
1206
06-17-2014 11:05 PM
by Anonymous User
Not applicable
Original User: HansVader
Hello everybody
I'm trying to change the datasource of a join.
The reason for that is the following: I read the source out of an given Lyr-File, in which the path is abolute. If I load another project, I want the datasource to be the one I load, and not the one standing in the lyr. That's why I need to change that.  (This Lyr thing is not important for the question but it may give you a better understanding. Otherwise the lyr can be seen as a static file which contains sources and tablenames).
For illustration:
This is the source I load. (Q:datasource\ele1_testings_fgdb\...
[ATTACH=CONFIG]34678[/ATTACH]
This is the source standing in the lyr and used for the join. (Q:\datasources\ele1_testing_mdb\...
[ATTACH=CONFIG]34679[/ATTACH]
So how it's done?
Thanks for every hint!
