Geoprocessor - C# - Create empty feature class using template for attribute fields
5369
06-17-2014 02:06 AM
BarryMason
I am using the ArcObjects SDK - C# and geoprocessor to create an empty polyline featureclass in a file geodatabase. This feature class will use an existing feature class in the file geodatabase as a template for its' fields.
I can get this to work ok using Python, however when I run my C#/ArcObjects code the required fields are not being created from the template. The output created only has the default featureclass attributes - OBJECTID, Shape and Shape_Length.
Can anyone point out where I am going wrong? I think I have used the correct syntax ok from ArcGIS Geoprocessing help. The code is shown below. Any help would be much appreciated to solve a frustrating problem!
Kind Regards
Barry Mason
Senior DBA/GIS Developer
SPT
Type factoryType = Type.GetTypeFromProgID("esriDataSourcesGDB.FileGDBWorkspaceFactory");
                            IWorkspaceFactory workspaceFactory = (IWorkspaceFactory)Activator.CreateInstance(factoryType);
                            IWorkspace out_path = workspaceFactory.OpenFromFile(@"C:\ProfLP.gdb", 0);
IFeatureWorkspace featureWorkspace = (ESRI.ArcGIS.Geodatabase.IFeatureWorkspace)out_path;
string out_name = "outputTest";
string geometry_type = "POLYLINE";
IFeatureLayer pInFeatLayer = new FeatureLayerClass();
IFeatureClass pInFeatClass = featureWorkspace.OpenFeatureClass("Profile42770");
pInFeatLayer.Name = pInFeatClass.AliasName;
pInFeatLayer.FeatureClass = pInFeatClass;
string has_m = "DISABLED";
string has_z = "DISABLED";
SpatialReferenceEnvironment spatialRefEnv = new SpatialReferenceEnvironmentClass();
ISpatialReference spatial_reference = (ISpatialReference)spatialRefEnv.CreateProjectedCoordinateSystem((int)ESRI.ArcGIS.Geometry.esriSRProjCSType.esriSRProjCS_BritishNationalGrid); //OSGB
string config_keyword = "";
Double spatial_grid_1 = 0;
Double spatial_grid_2 = 0;
Double spatial_grid_3 = 0;
// Create the geoprocessor.
IGeoProcessor2 gp = new GeoProcessorClass();
// Create an IVariantArray to hold the parameter values.
IVariantArray parameters = new VarArrayClass();
// Populate the variant array with parameter values.
parameters.Add(out_path);
parameters.Add(out_name);
parameters.Add(geometry_type);
parameters.Add(pInFeatLayer);
parameters.Add(has_m);
parameters.Add(has_z);
parameters.Add(spatial_reference);
//parameters.Add(config_keyword);
//parameters.Add(spatial_grid_1);
//parameters.Add(spatial_grid_2);
//parameters.Add(spatial_grid_3);
object sev = null;
// Execute the tool.
gp.Execute("CreateFeatureclass_management", parameters, null);
Console.WriteLine(gp.GetMessages(ref sev));
The console output is:
CreateFeatureclass C:\ProfLP.gdb outputTest POLYLINE Profile42770 DISABLED
DISABLED "PROJCS['British_National_Grid',GEOGCS['GCS_OSGB_1936',DATUM['D_O
SGB_1936',SPHEROID['Airy_1830',6377563.396,299.3249646]],PRIMEM['Greenwich',0.0]
,UNIT['Degree',0.0174532925199433]],PROJECTION['Transverse_Mercator'],PARAMETER[
'False_Easting',400000.0],PARAMETER['False_Northing',-100000.0],PARAMETER['Centr
al_Meridian',-2.0],PARAMETER['Scale_Factor',0.9996012717],PARAMETER['Latitude_Of
_Origin',49.0],UNIT['Meter',1.0]];-5220400 -15524400 10000;-100000 10000;-100000
10000;0.001;0.001;0.001;IsHighPrecision" # 0 0 0
Start Time: Tue Jun 17 11:02:40 2014
Succeeded at Tue Jun 17 11:02:40 2014 (Elapsed Time: 0.00 seconds)
ModyBuchbinder
Hi
Try to give the FeatureClass as the argument and not the FeatureLayer.
Translate the template layer into a string (full path) will always work.
Other then that there is better way to run GP tools in C# by using the real parameter names. Check this: http://resources.arcgis.com/en/help/arcobjects-net/conceptualhelp/0001/000100000161000000.htm
Have fun
Mody
AhmedEl-Sisi
As Mody said you can pass your template layer as string because it's a Multi value parameter.
You can also use ESRI.ArcGIS.DataManagementTools.CreateFeatureclass which is the same.
Another approach is to use IfeatureWorkspace.CreateFeatureClass and pass your fields from Template featureclass.
Regards,
BarryMason
Many thanks guys. Passing the template argument in as a string solved the problem. It was confusing because the geoprocessing help said that this argument was a feature layer.
Thanks again
Barry
