Problem with pTraceFlowSolver.FindFlowElements
7615
15
02-11-2011 05:14 PM
kromopawiro
Dear All,
I have coding snippet for tracing a network,Below this coding snippet :
Public Sub TraceNetworks(ByVal pMap As IMap, ByVal pFlowMethod As ESRI.ArcGIS.NetworkAnalysis.esriFlowMethod, ByVal pFeature As IFeature, ByRef pIEnumJunctionEIDInfo As ESRI.ArcGIS.NetworkAnalysis.IEnumEIDInfo, ByRef pIEnumEdgeEIDInfo As ESRI.ArcGIS.NetworkAnalysis.IEnumEIDInfo)
Dim pNetworkFeature As INetworkFeature
Dim pGeometricNetwork As IGeometricNetwork
Dim pTraceFlowSolver As ESRI.ArcGIS.NetworkAnalysis.ITraceFlowSolver
Dim pNetSolver As ESRI.ArcGIS.NetworkAnalysis.INetSolver
???Dim pNetwork As ESRI.ArcGIS.Geodatabase.INetwork
Dim pFeatureClass As IFeatureClass
Dim pJunctionEIDs As ESRI.ArcGIS.Geodatabase.IEnumNetEID = Nothing
Dim pEdgeEIDs As ESRI.ArcGIS.Geodatabase.IEnumNetEID = Nothing
pNetworkFeature = pFeature
pGeometricNetwork = pNetworkFeature.GeometricNetwork
pTraceFlowSolver = New ESRI.ArcGIS.NetworkAnalysis.TraceFlowSolver
pFeatureClass = pFeature.Table
???Create junction flag from selected feature
If pFeature.FeatureType = ESRI.ArcGIS.Geodatabase.esriFeatureType.esriFTComp lexEdge Or pFeature.FeatureType = ESRI.ArcGIS.Geodatabase.esriFeatureType.esriFTSimp leEdge Then
Dim pEdgeFlag As ESRI.ArcGIS.NetworkAnalysis.INetFlag
pEdgeFlag = New ESRI.ArcGIS.NetworkAnalysis.EdgeFlag
pEdgeFlag.UserClassID = pFeatureClass.FeatureClassID
pEdgeFlag.UserID = pFeature.OID
pEdgeFlag.UserSubID = -1
Dim pEdgeFlags(0) As ESRI.ArcGIS.NetworkAnalysis.IEdgeFlag
???Add the flag to the array
pEdgeFlags(0) = pEdgeFlag
pTraceFlowSolver.PutEdgeOrigins(1, pEdgeFlags(0))
ElseIf pFeature.FeatureType = ESRI.ArcGIS.Geodatabase.esriFeatureType.esriFTSimp leJunction Then
Dim pJunctionFlag As ESRI.ArcGIS.NetworkAnalysis.INetFlag
pJunctionFlag = New ESRI.ArcGIS.NetworkAnalysis.JunctionFlag
pJunctionFlag.UserClassID = pFeatureClass.FeatureClassID
pJunctionFlag.UserID = pFeature.OID
pJunctionFlag.UserSubID = 0
Dim pJunctionFlags(0) As ESRI.ArcGIS.NetworkAnalysis.IJunctionFlag
pJunctionFlags(0) = pJunctionFlag
pTraceFlowSolver.PutJunctionOrigins(1, pJunctionFlags(0))
Else
Exit Sub
End If
pTraceFlowSolver.TraceIndeterminateFlow = False
pTraceFlowSolver.FindFlowElements(pFlowMethod, ESRI.ArcGIS.NetworkAnalysis.esriFlowElements.esriF EJunctionsAndEdges, pJunctionEIDs, pEdgeEIDs)
Dim pEIDHelper As ESRI.ArcGIS.NetworkAnalysis.IEIDHelper
pEIDHelper = New ESRI.ArcGIS.NetworkAnalysis.EIDHelper
pEIDHelper.ReturnFeatures = True
pEIDHelper.GeometricNetwork = pGeometricNetwork
pEIDHelper.OutputSpatialReference = pMap.SpatialReference
pIEnumJunctionEIDInfo = pEIDHelper.CreateEnumEIDInfo(pJunctionEIDs)
pIEnumEdgeEIDInfo = pEIDHelper.CreateEnumEIDInfo(pEdgeEIDs)
Dim i As Integer
Dim pEIDInfo As ESRI.ArcGIS.NetworkAnalysis.IEIDInfo
Dim pDataset As IDataset
If pFlowMethod ESRI.ArcGIS.NetworkAnalysis.esriFlowMethod.esriFMC onnected Then
???m_pClearSelectCommand.OnClick()
???SetSelectionSymbol(True, pFlowMethod)
End If
For i = 1 To pIEnumJunctionEIDInfo.Count
pEIDInfo = pIEnumJunctionEIDInfo.Next
pFeature = pEIDInfo.Feature
pDataset = pFeature.Table
If Trim(UCase(Split(pDataset.Name, ???.???)(1))) ???ASET_NET_JUNCTIONS??? Then
pMap.SelectFeature(GetLayerByName(pDataset.Name), pFeature)
End If
End If
Next i
For i = 1 To pIEnumEdgeEIDInfo.Count
pEIDInfo = pIEnumEdgeEIDInfo.Next
End If
Next i
Map1.Refresh()
End Sub
I have error in statement ???pTraceFlowSolver.FindFlowElements(pFlowMethod, ESRI.ArcGIS.NetworkAnalysis.esriFlowElements.esriF EJunctionsAndEdges, pJunctionEIDs, pEdgeEIDs)???.
Message Error :
???Error HRESULT E_FAIL has been returned from a call to a COM component.???
I hope you can help me solution about problem above . Thank???s before
Regard
-Doni-
ShriramBhutada1
Here is a code sample with documentation
ArcObjects 10 .NET SDK Help
MilosMilicevic
Hello Shriram,
I am already using  it:
ITraceFlowSolverGEN pTraceFlowSolver = new TraceFlowSolverClass() as ITraceFlowSolverGEN;
pTraceFlowSolver.FindFlowElements(strTraceType, esriFlowElements.esriFEJunctionsAndEdges, out pJunctionEIDs, out pEdgeEIDs);
It seems like it always returns the result of a Connected trace, no matter which trace method I specify.
I have a test network that consists of a source (a reservoir), a sink (water meter) water hydrant and two pipes.
Every time i get all the junctions returned, but only when I set the flag
pTraceFlowSolver.TraceIndeterminateFlow = true;
Otherwise, I only get the trace starting junction.
Could this be a matter of weights?
I am using default net solver weights...
Do You have a working example of net solver weights usage?
Tnx in advance.
MilosMilicevic
So I think I know what the issue is:
My network does not have Flow Direction initialized.
I suppose that this is why up/downstream traces do not work.
Actually, I do not need this, because my app is supposed to return nearest upstream and nearest downstream node of a selected node.
All my features have a weight field, which is initialized to 32768 for sources and 65536 for sinks.
Any idea how can I determine if a neighbour node is upstream or downstream?
It occured to me to use FindConnected trace and then find all the sinks, and sources, and determine the nearest ones.
But I cannot figure out if the node is up or downstream
nicogis
Inizialized Flow Direction if you need downstream or upstream
you can use similiar code for find edge in downstream or upstream with your business logic.
 INetTopologyEditGEN netTopology = networkElements as INetTopologyEditGEN;
                            int edgeCount = netTopology.GetAdjacentEdgeCount(yourEIDJunction);
                            bool reverseOrientation;
                            int adjacentEdge;
                            for (int i = 0; i < edgeCount; i++)
                                netTopology.GetAdjacentEdge(yourEIDJunction, i, out adjacentEdge, out reverseOrientation);
                                netTopology.GetFromToJunctionEIDs(adjacentEdge, out fromEIDJunction, out toEIDJunction);
reverseOrientation = true // into Junction   -> upstream
reverseOrientation = false // exit Junction   -> downstream
MilosMilicevic
Hello Domenico,
Works great, thanks.
Thanks a lot.
Just one question:
Does this relay on the NetworkAncilarryRole Field (determines flow according to the Source/Sink value of the junction) ?
Because if it relies on that, it will not work for me.
I need nearest adjacent junctions on the up and downstream side, but according to NetWeight field.
Could I use IForwardStarGEN interface:
http://help.arcgis.com/en/sdk/10.0/arcobjects_net/componenthelp/index.html#/IForwardStarGEN_Interfac...
It seems to have methods that take notice of weights...
Tnx again.
nicogis
Yes, it 's similar INetTopologyEditGen  but with IForwardStarGEN you have also the weight!
