Problem when I work whit FGDB raster (no whit Folder raster) why?
1079
05-30-2013 02:46 AM
martinmaretta
Hi i have one problem. I using  code like this:
            Dim pOutputRaster As IRaster
            pOutputRaster = pReclass.Reclass(pLandCover, pReclassTable, "ID", "ID", "MANNING", True)
            pMapAlgebraOp.BindRaster(pOutputRaster, "Mann")
            pOutputRaster = pMapAlgebraOp.Execute("FLOAT([Mann]) / 100.0")
            pMapAlgebraOp.UnbindRaster("Mann")
And when i use raster from Folder everything is OK, BUT whe i Use rasters from FGDB - reclass is running fine, and  i create pOutputRaster (I see it in my TEMP directory). But when i use pMapAlgebraOP.execute  i have error "_message = "ERROR 010316: Unable to open the input raster: C:\USERS\MATTKO\APPDATA\LOCAL\TEMP\ITEMP\G_G402 ERROR 010067: Error in executing grid expression." and my raster is disapear from  TEMP directory.
Do anybody know what´s the problem??  thank a lot.
DuncanHornby
MVP Notable Contributor
Martin,
The field deliminters in a file geodatabase are " and not [.
So I'm guessing your line pOutputRaster = pMapAlgebraOp.Execute("FLOAT([Mann]) / 100.0") should become
Dim sQuery as String
sQuery = "FLOAT(" & chr(34) & "Mann" & chr(34) & ") / 100.0"
pOutputRaster = pMapAlgebraOp.Execute(sQuery)
On a side note you can determine the deliminiter using ISQLSyntax Interface.
Duncan
martinmaretta
Thanks for response, but syntax is OK. this is Raster map algebra syntax no field calculator (or Query) syntax. But i found very strange behaviour of FGDB raster in mapAlgebra.
1) when i use directly FGDB raster to mapAlgebra and then other opration (except MapAlgebra) it runs OK.
pMapAlgebraOp.BindRaster(pFGDBRaster, "Mann")
pOutputRaster = pReclass.Reclass(pOutputRaster , pReclassTable, "ID", "ID", "MANNING", True)
2) when i use FGDB raster first to other operation and then to MapAlgebra it runs whit ERROR
pOutputRaster = pReclass.Reclass(pFGDBRaster, pReclassTable, "ID", "ID", "MANNING", True)
pMapAlgebraOp.BindRaster(pOutputRaster , "Mann")
3) when i use FGDB raster first to other operation then another one except MapAlgebra and then to MapAlgebra it runsOK
Dim pMapOp As IMathOp
pMapOp = New RasterMathOps
pOutputRaster = pMapOp.Float(pOutputRaster )
4) when i use FGDB raster first to other operation then save this raster to disk and then use it in MapAlgebra it run OK
