Populate Textbox with excel cell value
1588
12-30-2010 10:53 AM
ColbyParnell
Is this possible.
I can open the excel file i want to get the data from but im not sure how to get the corrisponding values into the user form.
Code i have to open excel via button click:
Private Sub OpenNewWarrant()
Dim VolDate As Date
Dim xlApp As Object
    Set xlApp = CreateObject("excel.application")
    xlApp.Visible = True
    Set myfile = xlApp.Workbooks.Open("C:\AirPhoto\Test.xls") 'etc...
    Set xlApp = Nothing    ' the application, then release the reference.
End Sub
Im thinking something like this but obviously it needs to be tweaked...
 tb6.Value = myfile.Workbooks.ActiveSheet("C8").Value
ColbyParnell
Ok so if i open the file and populate right away this works like a charm:
Private Sub CommandButton1_Click()
Dim xlApp As Object
Dim myfile As ExcelWorkspaceFactory
    tb6.Value = xlApp.ActiveWorkbook.Sheets("sheet1").Range("C8").Value
But if i change something in the cell and try to update it returns an error of: runtime error 91 Object variable or with block variable not set
