Populate geodatabase annotation feature from a shape point layer (VBA)
874
09-07-2010 06:27 AM
MaëlREBOUX
Hello.
I have a shape with points and attributes.
I would like to obtain some annotations in an annotation feature class in a file GeoDatabase.
I have difficulties with the IannotateLayerProperties
Public Function CreaAnnoFromPoint()
    'les variables pour utiliser ArcMap
    Dim pMxApp As IMxApplication
    Dim pDoc As IMxDocument
    Dim pMap As IMap
    'les objets ArcMap
    Set pMxApp = Application
    Set pDoc = Application.Document
    Set pMap = pDoc.FocusMap
    Dim plPoint As IFeatureLayer
    Dim pfPoint As IFeature
    Dim plAnno As IFeatureLayer
    Dim pfAnnoClass As IFeatureClass
    Dim pfAnno As IFeature
    Dim pCursor As ICursor
    'set the layers
    Set plPoint = pMap.Layer(1)
    Set plAnno = pMap.Layer(0)
        Set pfAnnoClass = plAnno.FeatureClass
    'cursor
    Set pCursor = plPoint.Search(Nothing, False)
    'go to first line
    Set pfPoint = pCursor.NextRow
    connString = "...\data\my_file_geodb.gdb"
    Dim pWorkspace As IWorkspace
    Dim pWorkspaceFactory As IWorkspaceFactory
    Set openFGDBWorkspace = Nothing
    Set pWorkspaceFactory = New FileGDBWorkspaceFactory
    Set pWorkspace = pWorkspaceFactory.OpenFromFile(connString, 0)
    Set openFGDBWorkspace = pWorkspace
    'open edit session
        Dim pEditor As IEditor
        Set pEditor = Application.FindExtensionByName("ESRI Object Editor")
        pEditor.StartEditing pWorkspace
    Debug.Print "session open"
    Dim l As Long
    'the loop on the points
    While Not (pfPoint Is Nothing)
        zSymbolID = 3
        zTextString = pfPoint.Value(8)
        zFontName = pfPoint.Value(9)
        zFontSize = pfPoint.Value(10)
        zAngle = pfPoint.Value(18)
        voie_id = pfPoint.Value(25)
        adresse_id = pfPoint.Value(26)
        adresse_numero = pfPoint.Value(27)
        adresse_extension = pfPoint.Value(28)
        adresse_batiment = pfPoint.Value(29)
        adresse_origine = pfPoint.Value(30)
        'for test
        Debug.Print adresse_id
        'create a new record on the annotation feature class
           Dim pElement As IElement
           Dim pTextElement As ITextElement
           Dim pPoint As esriGeometry.IPoint
           Dim pAnnotationFeature As IAnnotateFeature
           Dim pAnnotationProperties As IAnnotateLayerProperties
           'definition of annotation's propreties
            Set pTextElement = New TextElement
                pTextElement.Text = zTextString
                pTextElement.ScaleText = True
            'what else ?
        l = l + 1
        If (l = 10) Then GoTo fin
        'Ligne suivante
    Wend
fin:
    'on ferme la session
    pEditor.StopEditing True
    Debug.Print "session fermée"
    Debug.Print "==== FIN ===="
End Function
Thank you for your help.
MaëlREBOUX
OK. Found this : http://edndoc.esri.com/arcobjects/8.3/Samples/Geodatabase/Database%20Tools/TextFile%20to%20Annotatio...
We made an adaptation of this code. The scenario is :
- load a geodb point feature class, as source
- load an empty geodb annotation feature class, as target
- create annotations with a fixed Symbol ID and the angle and TextString Value from the point layer
- create and populate the bonus fields
And it works !  🙂
