Doubt with INewTextFeedback
1005
09-08-2010 03:58 AM
VictorAparicio
Hi!
Has anyone used the NewTextFeedBack class? If you read the description in the table of the classes that implement the IDisplayFeedback, it says that it is used to move a text display feedback object, just the same as the MoveTextFeedback does. Also, if you read the description inside the INewTextFeedback interface help, it says that is used to rotate a text feedback, the same as the IRotateTextFeedback...
I have found no samples about how this class works. Anyone has any ideas??? Is there a bug in the descriptions of the class?
Thanks in advance!
