Points to Polyline - How to the spatial reference?
2916
01-16-2014 08:10 AM
ShaningYu
Honored Contributor
In a project, I created a polyline through a collection of points. The related code is below:
// Create and add segments
ISegmentCollection path = new ESRI.ArcGIS.Geometry.PathClass();
object obj = Type.Missing;
for (int i = 1; i < pointsCollection.Count; i++) {
ILine pLine = CreateLine(pointsCollection[i - 1], pointsCollection);
path.AddSegment((ISegment)pLine, ref obj, ref obj);
// Get the Polyline
ESRI.ArcGIS.Geometry.IPolyline pSegPoly = new ESRI.ArcGIS.Geometry.PolylineClass();
ESRI.ArcGIS.Geometry.IGeometryCollection pGeoColl = pSegPoly as IGeometryCollection;
pGeoColl.AddGeometry((IGeometry)path, ref obj, ref obj);
pGeoColl.GeometriesChanged();
// Get json results
JsonObject onSegment = Conversion.ToJsonObject((IPolyline)pGeoColl);
List<JsonObject> jsonGeometry = new List<JsonObject>();
jsonGeometry.Add(onSegment);
JsonObject resultJsonObject = new JsonObject();
resultJsonObject.AddArray("Geometry", jsonGeometry.ToArray());
// Get byte array of json and return results, which will be the output of ArcGIS Server SOE service
byte[] result = Encoding.UTF8.GetBytes(resultJsonObject.ToJson());
return result;
The data from my ArcGIS Server's service call looks like:
{ "Geometry": [ {
"paths": [ [
[-8575118.2321458999,4707114.1745275566], ... [-8575820.374931246,4707389.1788524361] ] ]
Ideally, after the { } block, there should be
"spatialReference":{"wkid":102100}}, which is the same as that of the points in the point collection.
How can the SR information be added to the polyline?
ShaningYu
Honored Contributor
Found to be very simple, just add
   pSegPoly.SpatialReference = point.SpatialReference;
Then, the result from ArcGIS Server's SOE service contains the SR as needed.  Thread is to be closed.
ShaningYu
Honored Contributor
