Outputting from an custom geoprocessing tool (IGPFunction)
2787
06-11-2013 02:56 PM
GuénoléChoné
I'm creating a custom geoprocessing tool in C# (implementing IGPFunction2), and I cannot succeed in creating the output of the gp tool (in my case, a point feature class, but the kind of output I try to create doesn't really matter, it could be a simple table or even a raster...). I guess I need to start by creating the IGPValue (same thing than for the tool's inputs), like that:
public void Execute(IArray paramvalues, ITrackCancel trackcancel, IGPEnvironmentManager envMgr, IGPMessages message)
IGPValue gp_output = m_GPUtilities.UnpackGPValue((IGPParameter3)paramvalues.get_Element(3));
Than what should I do ? How to create a empty (to begin with...) feature class from this IGPValue  ?
TimSexton1
You have to define an output parameter in the ParameterInfo array of your GP tool, then set the value of that output parameter in the Execute() method.  I've included a small code sample below:
        // This is the location where the parameters to the Function Tool are defined.
        // This property returns an IArray of parameter objects (IGPParameter).
        // These objects define the characteristics of the input and output parameters.
        public IArray ParameterInfo
            get
                //Array to the hold the parameters
                IArray parameters = new ArrayClass();
                //Input DataType is GPStringType
                IGPParameterEdit3 inputParameter = new GPParameterClass();
                inputParameter.DataType = new GPStringTypeClass();
                // Default Value object is GPString
                inputParameter.Value = new GPStringClass();
                // Set Input Parameter properties
                inputParameter.Direction = esriGPParameterDirection.esriGPParameterDirectionInput;
                inputParameter.DisplayName = "Station ID";
                inputParameter.Name = "stationid";
                inputParameter.ParameterType = esriGPParameterType.esriGPParameterTypeRequired;
                parameters.Add(inputParameter);
                //Out DataType is GPStringType
                IGPParameterEdit3 outputParameter = new GPParameterClass();
                outputParameter.DataType = new GPStringTypeClass();
                outputParameter.Value = new GPStringClass();
                // Set Output Parameter properties
                outputParameter.Direction = esriGPParameterDirection.esriGPParameterDirectionOutput;
                outputParameter.DisplayName = "Output";
                outputParameter.Name = "output";
                outputParameter.ParameterType = esriGPParameterType.esriGPParameterTypeDerived;
                parameters.Add(outputParameter);
                return parameters;
... and then
        // Execute: Execute the function given the array of the parameters
            bool success = false;
            // Get the first Input Parameter
            IGPParameter inputParameter = (IGPParameter)paramvalues.get_Element(0);
            // UnPackGPValue. This ensures you get the value either form the dataelement or GpVariable (ModelBuilder)
            IGPValue inputValue = m_GPUtilities.UnpackGPValue(inputParameter);
            // input station ID
            string inputStringValue = inputValue.GetAsText();
            if (!string.IsNullOrEmpty(inputStringValue))
                success = true;
            if (!success)
                message.AddError(2, "An error occurred during the test.");
            else
                message.AddMessage("Test completed successfully!");
            // Set the Output Parameter
            IGPParameter outputParameter = (IGPParameter)paramvalues.get_Element(1);
            IGPString outValue = new GPStringClass();
            outValue.Value = "This is my output showing input value of '" + inputStringValue + "'";
            m_GPUtilities.PackGPValue((IGPValue)outValue, outputParameter);
