Opening KML File in active ArcMap Window
1303
05-31-2013 12:47 PM
ZachBaker
I'm writing a program which needs to interface with ArcMap, I need to import a KML file and typically I would run it just by calling
ArcMap.exe <path to KML file>
The problem is, this loads a new session of ArcMap. Is there a way I can have it open in a copy currently running? I couldn't find any pages with commandline switches for ArcMap.
Thanks
TerryGiles
I don't think you can directly add KML to ArcMap (I could be wrong here), but you can use the KMLtoLayer tool to make a .lyr file in the user's temp folder and then add that layer.
It sounds like you're code is not running inside of ArcMap but another application.  If so, try using the AppROT class (in Esri.ArcGIS.Framework) to find ArcMap (if it's open) or to open ArcMap & add the layer created from the geoprocessing tool.
ZachBaker
^ I think that is exactly what I needed to hear.  That puts me in the right direction of where to look.
DuncanHornby
MVP Notable Contributor
Zach,
As Terry indicated you want to be driving ArcMap using Automation, a similar question recently popped up on this forum thread. Try searching for the topic Automation on this forum and keywords like AppROT and IObjectFactory.
Duncan
