Opening an MXD outside of an arcMap Session
2956
08-26-2010 11:09 AM
MichaelAdornetto
I've been running geoprocessing functions in a stand alone program that consumes an ArcGIS Desktop license.  One of the Models I call uses "Map to KML" which can use an MXD file as a parameter,  It works fine but I would like to tweak it a bit. I have code that produces the KML I want but it needs to run in ArcMAP.  I need to develop a custom geoprocessor tool taht I can feed an MXD to, however I'm unfamiliar with how to reference the layers inside a map document out side of an ArcMap Session.  Does anyone know how to do this, can I open an MXD without the ArcMAp UI or Map Control?  I image the tollbox item "Map to KML" does this.
thanks
MarkWelsh
Check out the IMapDocument interface.  It is built to allow this type of activity you are interested in.  You can use it to open a map document, read layers, etc. without the code having to run inside an mxd.
Mark
