Opening a Shapefile (C++)
2549
09-27-2010 12:56 PM
MattMoyles
I've been trying to open a shapefile as a workspace in ArcObjects C++ 10.  I've been trying to use this sample as a guide to go by but I can't seem to open my file. (http://help.arcgis.com/en/sdk/10.0/arcobjects_cpp/conceptualhelp/index.html#/Simplify_feature_geomet...)
int _tmain(int argc, _TCHAR* argv[])
    CoInitialize(0);
    ESRI_SET_VERSION(esriArcGISDesktop);
    CComBSTR srcPath;
    char path[] = "C:/points/Points_10000.shp";
    HRESULT hr = GetParentDirFromFullPath(path, &srcPath);
    CComBSTR targetWorkspacePath = L"C:\\Users\\matt.moyles\\Documents\\Visual Studio 2008\\Projects\\PointBenchmarksStandalone\\Debug";
    IWorkspaceFactoryPtr sourceWorkspaceFactory(CLSID_ShapefileWorkspaceFactory);
    IWorkspacePtr sourceWorkspace;
    hr = sourceWorkspaceFactory->OpenFromFile(srcPath, NULL, &sourceWorkspace);
    if( FAILED(hr) || sourceWorkspace == 0 )
        std::wcerr << L"Couldn't open workspace " << (BSTR) srcPath << std::endl;
        return 1;
    ShutdownApp();
    CoUninitialize();
    return 0;
This line sourceWorkspaceFactory->OpenFromFile(srcPath, NULL, &sourceWorkspace); is not returning the IWorkspace.  Any help would be appreciated, I've been stuck for a few hours now.
HeribertoMantilla_Santamaría
Hi
Is possible the var srcPath is empty or invalid, or try to change the NULL parameter in OpenFromFile
MattMoyles
Thanks, I can verify that the srcPath variable is set to the correct path because I get "Couldn't open workspace c:/points"  I tried to put in a value for the 2nd HWND parameter but it didn't seem to change anything.
Hi again.
Try change slash for backslash in the path.
MattMoyles
I've tried a bunch of different little tweaks like that.  I've even tried just changing the function call to:
hr = sourceWorkspaceFactory->OpenFromFile((BSTR)"c:\\points", 0, &sourceWorkspace);
with no luck... I can run similar code in .NET/C# just fine which baffles me...
