Nunit Testing in ArcObjects
832
04-07-2014 11:31 PM
upendrapaladugu
    I am trying to use Nunit testing in Arc Objects with Visual Studio 2010 and ArcGIS 10.2 with C#.
    The main problem seems the initializing of the Arc Objects.
    I used the below code for licence initialization
    [SetUp]
        public void Init()
            ESRI.ArcGIS.RuntimeManager.Bind(ESRI.ArcGIS.ProductCode.Desktop);
            var aoInit = new AoInitializeClass();
            esriLicenseStatus status = aoInit.Initialize(esriLicenseProductCode.esriLicenseProductCodeStandard);
    The license is correctly checked out.
    After add some code in TestCase and run the application, it throws exception:
  Failure: SetUp : System.DllNotFoundException : Unable to load DLL 'ArcGISVersion.dll': The specified module could not be found. (   Exception from HRESULT: 0x8007007E).
   But I given Esri.ArcGIS.Version dll reference.
   Does any one worked on Nunit Testing in Arcobjects? Please give the suggetions for this.
   Thanks & Regards,
   Upendra
