Need to get addressabilty to the IApplication object
1826
8
12-03-2013 12:30 PM
MichaelEber
I'm working on a server component that is being run and tested in ArcMap as a tool.
The code is running and we are getting results but not expected results.
Part of the process creates a cost array which we want to add to the map.  I have the basics ONCE I HAVE A MAP, but to get the   map I need to create the IApplication object.
So running as a tool without any ESRI templates in my code...how do I create the IApplicationObject for accessing the maps in ArcMap???
Thanks
NeilClemmons
Honored Contributor
How are you running this code?  Your post says you are testing the component inside of ArcMap, so whatever mechanism you're using to run that code should have access to the application.  For instance, if you've created a command then it is given a reference to the application in its OnCreate method.
RichardWatson
You have to run ArcMap to get IApplication.  This implies that your code/DLL will execute within the context of the ArcMap process.
I think that since you are developing a server tool that you should not be using IApplication because that interface is only available in ArcGIS For Desktop applications:
http://resources.arcgis.com/en/help/arcobjects-net/componenthelp/index.html#/Overview/00230000010v00...
MichaelEber
Neil,
Yes it is a service, however for testing we are running it as a tool inside ArcMap.  Since I am running inside the context of ArcMap can I still get a way to gain access to IApplication?
NeilClemmons
Honored Contributor
Neil,
Yes, if you are creating the tool using COM then the hook parameter passed into ICommand.OnCreate is of type IApplication, you just need to cast it and keep up with it.  If you're creating an add-in then there is a global object available that will give you the reference.  I don't use add-ins so I can't tell you what it's called but I'm sure it's in the documentation.
MichaelEber
For tools we have a class that defines the parameters, value types, and the IGPEnvironmentManager along with the IGPMessages object.  I think that it would make sense that it is in the IGPEnvironmentManager but I'll have to start search on that to find out.
Thanks.
MichaelEber
RichardWatson
ArcObjects Library Reference (Framework)
