Need help figuring out errors with .NET in 10.1
2763
6
12-28-2012 08:43 AM
PatrickGross
This morning, I opened up a .NET project I created in VB 2010 Express over a year ago.  I upgraded to a new machine and also from 10 to 10.1.  I noticed that the licensing procedure has changed, but I can't figure out a few things:
1) Why would ESRI.ArcGIS.esriSystem.dll not be in my DotNet folder?
2) Is my method for initializing the license the wrong way to do it?
I'm using this code to retrieve the coordinates of the corners of a set of rasters.  I tried searching for information on how to initialize a license for a couple hours now with no solid reason as to why my reference to ESRI.ArcGIS.esriSystem won't work.
Thanks in advance!
[ATTACH=CONFIG]20275[/ATTACH]
KenBuja
MVP Esteemed Contributor
Remove them and add them back again using "Add ArcGIS Reference"
RichardWatson
ESRI.ArcGIS.System.dll is the assembly that you seek.
KenBuja
In a test project, I have ESRI.ArcGIS.System as a reference and can add the line
Dim test As New ESRI.ArcGIS.esriSystem.AoInitialize
10.1 has made changes with the enumerators. See What's New in the Help
[TABLE="class: dtTable"]                   Prior to 10.1                                                     10.1                                  esriLicenseProductCodeArcView                 esriLicenseProductCodeBasic                 esriLicenseProductCodeArcEditor                 esriLicenseProductCodeStandard                 esriLicenseProductCodeArcInfo                 esriLicenseProductCodeAdvanced
[/TABLE]
PatrickGross
When I declare "Imports ESRI.ArcGIS.System" at the top, VB 2010 gives me the following error:
"Namespace or type specified in the Imports 'ESRI.ArcGIS.System' doesn't contain any public member or cannot be found. Make sure the namespace or the type is defined and contains at least one public member. Make sure the imported element name doesn't use any aliases."
I checked my references and it's listed in there, so I don't know what setting I need to change.
PatrickGross
I think I found the culprit.
[ATTACH=CONFIG]20282[/ATTACH]
So, how do I repair these references?
KenBuja
PatrickGross
Thanks, y'all!  I figured it was some dumb mistake by me. :rolleyes:
