Need a piece of code to check FeatureLayer and more ...
1500
10-20-2017 11:16 AM
ShaningYu
Honored Contributor
I need a piece of code to check if a layer in ArcMap is a FeautureLayer.
                IMap pMap = m_mxDoc.FocusMap;
                for (int i = 0; i < m_mxDoc.Maps.Count; i++) {
                    ILayer pLayer = pMap.Layer;
                    //if (typeof(pMap.Layer) is IFeatureLayer )   ???  How to code here?
Appreciate if you can help.
Tags (1)
DuncanHornby
MVP Notable Contributor
Here is some code in VBA that shows you how to test if object is of type IFeatureLayer
Public Sub test()
 Dim pMxDoc As IMxDocument
 Set pMxDoc = ThisDocument
 Dim pMap As IMap
 Set pMap = pMxDoc.FocusMap
 Dim pEnumLayers As IEnumLayer
 Set pEnumLayers = pMap.Layers
 Dim pLayer As ILayer
 Set pLayer = pEnumLayers.Next
 Do While Not (pLayer Is Nothing)
 If TypeOf pLayer Is IFeatureLayer Then
 Debug.Print "FeatureLayer found!"
 End If
 Loop
End Sub
ShaningYu
Honored Contributor
Revised the code as:
if (m_Map.Layer is IFeatureLayer) { ... }
No need to use typeof(...)   Thanks.
AllanMills
You'd be better of enumerating the layers to only get feature layers. For the above code, when you convert it to a .NET equivalent you can provide an ID to the layers command:
 Dim pId As New UID
 pId.Value = "{40A9E885-5533-11d0-98BE-00805F7CED21}"
 Dim pEnumLayers As IEnumLayer = pMap.Layers(pId, True)
The pId value tells Arc what kind of layers to look for. This page: ArcObjects Help for .NET developers tells you the GUID values for different data types.
