mxd-content to filegeodatabase converter
1008
09-29-2010 02:18 AM
mariuskolleck
hi !
I'm using VB.NET to create a programm which opens a *.mxd File, reads the layers, and exports those to a filegeodatabase. I'm new to arcobjects, but i've read a lot and the main function of my program works as far. It reads the mxd, takes all features existing in it and all rasters, and copies them to my fgdb.
but now i'm kind of stuck, and i need some hints to finish it :
-  how can i get the tables in the mxd file ? My program only gets the features and the rasters
pMapDoc = New MapDocument
        pMapDoc.Open(sMXD)
        pMap = pMapDoc.Map(0)
        pLayers = pMap.Layers
        pLayers.Reset()
-   is it posible to read the sql-query which is applied to a layer, so my program only copies the features, which are actualy displayed in my mxd ?
In addition i'll post some code snippets, maybe it helps !
this is how i convert the features:
    Public Sub GeolineTestAuslesen(ByVal str As String)
        Dim paramsl As PropertySet
        Dim TrackCancel As ITrackCancel = Nothing
        Dim pGPMessages As IGPMessages
        Dim aMessage As GPMessage
        Dim g As New GpDispatch
        paramsl = New PropertySet
        paramsl.SetProperty("Input_Features", dgnpath & "\" & str)
        paramsl.SetProperty("Output_Geodatabase", preExistingGDB)
        paramsl.SetProperty("Derived_Geodatabase", preExistingGDB)
        pGPMessages = g.Execute("FeatureClassToGeodatabase", paramsl, TrackCancel)
        Console.WriteLine()
        sw.WriteLine("----Feature schreiben----")
        For n = 0 To pGPMessages.Count - 1
            aMessage = pGPMessages.Messages.Element(n)
            Console.WriteLine(aMessage.Description)
            sw.WriteLine()
            sw.WriteLine(aMessage.Description)
            sw.WriteLine()
            Console.WriteLine()
    End Sub
this is how i read in the layers and save them to a generic list :
        pMapDoc.Open(sMXD)
        pLayers.Reset()
        Header()
        Dim i As Integer = 0
        pLayer = pLayers.Next
        fcs.Add(pLayer)
        Console.Write("Layer " & i & " : ")
        Console.ForegroundColor = ConsoleColor.Green
        Console.Write(pLayer.Name.ToString)
        Console.ResetColor()
        Console.WriteLine(" eingelesen")
        sw.WriteLine()
        sw.WriteLine("Layer " & i & " : " & pLayer.Name.ToString & " eingelesen")
        i += 1
        Do While Not pLayer Is Nothing
            If pLayer Is Nothing Then
            Else
                fcs.Add(pLayer)
            End If
            i = i + 1
        Loop
Maybe someone can help, i really want to get this done, cause im a student and i'm on my internship, and its my challenge to do this 🙂 thank you !
