Moving a Feature Class out of a Feature Dataset
1416
07-20-2010 10:14 AM
PaulBlessing
I have a workflow where I need some feature classes in a feature dataset/geometric network temporarily, but later they no longer need to be part of the feature dataset.  I'm able to delete the geometric network using ArcObjects just fine, but is there a way to programmatically move the feature classes out of the feature dataset and just back into the workspace level?
JamesMacKay
Hi Paul,
Within a geodatabase, the AddDataset method of the IDatasetContainer interface can be used to move feature classes between feature datasets and the workspace level. Here's a bit more information:
http://resources.esri.com/help/9.3/arcgisdesktop/arcobjects/esrigeodatabase/IDatasetContainer.htm
Cheers,
James
PaulBlessing
James, that works perfectly, thanks.  I had found the IDatasetContainer#addDataset method before, but I was getting errors when using it.  Turns out it was my fault and after trying it again everything worked.
