MapControl cursor flicker in java
884
04-05-2011 04:13 AM
PatrickAdams
I have a java application that includes an ArcObjects mapcontrol, when the mouse is over the control it uses the mouse cursor that is correct  for the currently selected tool. However if you make any changes to the rest of the window, for instance changing the value of the text in a label, then this cursor changes to be the java cursor for the map control, and remains as this Java cursor till the mouse is moved. My question is how do I prevent it from changing the cursor?
