looping through the records of a standalone table
3143
6
08-29-2010 11:52 AM
DavidKelly1
I am using VBA in version 9.3.1. I just want to loop through the records of a standalone table I added to a mxd.
Dim pAccessWSF As IWorkspaceFactory
Dim pWorkSpace As IWorkspace
Dim pFeatws As IFeatureWorkspace
Dim ptable As ITable
Set pAccessWSF = New AccessWorkspaceFactory
Set pWorkSpace = pAccessWSF.OpenFromFile("C:\Calsmoke\CalSmoke.mdb", 0)
Set pFeatws = pWorkSpace
Set ptable = pFeatws.OpenTable("Daysmoke_emissions")
Dim pMap As IMap
Dim pMx As IMxDocument
Set pMx = ThisDocument
Set pMap = pMx.FocusMap
Set pStTab = New StandaloneTable
Set pStTab.Table = ptable
Set pStTabColl = pMap
pStTabColl.AddStandaloneTable pStTab
pMx.UpdateContents
Dim pRow As IRow
Set pRow = pStTab.Table.GetRow(1)
When I execute the last line of code I get the following error message a run time error -2147467259: syntax error(missing operator) in query expression '=0'.
David
NirYoscovitz
Hi David,
Your code looks OK.
Does your table contain an OID column?
Regards,
Nir
NeilClemmons
Honored Contributor
You access records in a table via a query.  You then loop through the cursor returned by that query.  To get all records in a table, pass in a null reference for the query filter.
Dim cursor As ICursor
Set cursor = table.Search(Nothing, False)
Dim row As IRow
Set row = cursor.NextRow
Do While Not row Is Nothing
  ' do something
Loop
DavidKelly1
Neil,
I changed the code to use a cursor as you suggested and it works.  The access table I am trying to update does not have a OID field so I get an error message when I store the Lat Long coordinates in the table.  The code I am using is below:
Dim pTables As IStandaloneTableCollection
Dim pTableName As String
Dim pStTab As IStandaloneTable
Dim pStTabColl As IStandaloneTableCollection
Dim pMap As IMap
pMx.UpdateContents
Dim pRow As IRow
Dim pCenterXFld As IField
Dim pCenterXValue As Double
Dim pPoint As IPoint
Dim pGCS As IGeographicCoordinateSystem
Dim pSpRFc As ISpatialReferenceFactory
Set pSpRFc = New SpatialReferenceEnvironment
Set pGCS = pSpRFc.CreateGeographicCoordinateSystem(esriSRGeoCS_WGS1984)
Dim pTabCursor As ICursor
Set pTabCursor = pStTab.Table.Search(Nothing, False)
Set pRow = pTabCursor.NextRow
While Not pRow Is Nothing
    Set pPoint = New Point
    pPoint.x = pRow.Value(10)
    Debug.Print pPoint.x
    pPoint.y = pRow.Value(11)
    pPoint.PutCoords pRow.Value(10), pRow.Value(11)
    pPoint.Project pGCS
    pRow.Value(12) = pPoint.y
    pRow.Value(13) = pPoint.x
    'pRow.Store
Wend
Thanks for your help.
David Kelly
DavidKelly1
My response above may have not been clear. I am trying to update two lat/long fields in a table in a personal geodatabase; it is a standalone table. Using the code above I can loop through the table and correctly generate the Lat/Longs from the Lambert coordinates in two other fields. Since the table does not have an OID field it will not let me store the generated Lat/Longs in their fields in the table.
How do you update fields in a standalone table in a personal geodatabase?
Thanks for your help,
David Kelly
vincentLahaye
hi,
did you tried update cursor.
Set pTabCursor = pStTab.Table.update(Nothing, false)
pPoint.Project pGCS
pTabCursor.UpdateRow(pRow)
Wend
DavidKelly1
The Update cursor worked.  Thank you!  I was getting very frustrated.
