linux  arcengine for java   openFeatureClass(Unknown Source)
882
03-25-2011 07:51 PM
zhuxiaochen
I use arcengine for java in linux operation.
The exception I got was "AutomationException: 0x80004005 - Unspecified error".
My product version is arcengine 9.3 java for linux.
error in
at com.esri.arcgis.geodatabase.Workspace.openFeatureClass(Unknown Source)
code
String workspacePath = arcGISHome + "/java/samples/data/usa";
String featureClassName = "states.shp";
File shapefileFile = new File(workspacePath, featureClassName);
if (!shapefileFile.exists()) {
System.out.println("Shapefile " + shapefileFile.getAbsolutePath() + " doesn't exist. Exiting.");
System.exit(-1);
System.out.println("Shapefile: " + shapefileFile.getAbsolutePath());
try {
AoInitialize aoInitializer = new AoInitialize();
aoInitializer.initialize(esriLicenseProductCode.esriLicenseProductCodeEngine);
ShapefileWorkspaceFactory shapefileWorkspaceFactory = new ShapefileWorkspaceFactory();
Workspace workspace = new Workspace(shapefileWorkspaceFactory.openFromFile(workspacePath, 0));
FeatureClass featureClass = new FeatureClass(workspace.openFeatureClass(featureClassName)); int numFeatures = featureClass.featureCount(null);
System.out.println("There are " + numFeatures + " features:");
for (int i = 0; i < numFeatures; i++){
IFeature feature = featureClass.getFeature(i);
IGeometry geometry = feature.getShapeCopy();
System.out.println("Feature " + i + ": ");
System.out.println(getStringFromShape(geometry));
if (i >= 9) {
break; // 10 is enough
aoInitializer.shutdown();
System.out.println("Sample finished.");
} catch (Exception e) {
e.printStackTrace();
why use workspace.openFeatureClass in some errors,the shapefile's path and name is correct .
Any solution or workaround this?
Thank you very much in advance
EricBader
Honored Contributor
Hello!
Do you call EngineInitializer.initializeEngine() anywhere? You need to call this before you do AoInitialize.
zhuxiaochen
Hello!
Thanks very much!
I add EngineInitializer.initializeEngine() into the front of AoInitialize ,
but the same error.
code :
System.exit(-1);
try {
EngineInitializer.initializeEngine() ;
if (i >= 9) {
error:
