License needed for AxPageLayout Control
1038
01-28-2011 08:32 AM
GregoryDillon
I just upgraded to 10 and now my .Net solution seems stop working when it hits the line:
AxPageLayoutControl1.LoadMxFile(MXDFilePath)
I don't get an error, it just quits.    Has the licensing changed with 10?   I used to use a desktop license with 9.3.1.
I've added the new binding (see below):
Public Sub New()
        ESRI.ArcGIS.RuntimeManager.BindLicense(ProductCode.EngineOrDesktop)
        ' This call is required by the Windows Form Designer.
        InitializeComponent()
        ' Add any initialization after the InitializeComponent() call.
    End Sub
and call the following subroutine in the form_load event
Private Sub HandleLicense()
        Dim AoInit As ESRI.ArcGIS.esriSystem.AoInitialize = New ESRI.ArcGIS.esriSystem.AoInitialize
        If AoInit.IsProductCodeAvailable(ESRI.ArcGIS.esriSystem.esriLicenseProductCode.esriLicenseProductCodeArcServer) = ESRI.ArcGIS.esriSystem.esriLicenseStatus.esriLicenseAvailable Then
            AoInit.Initialize(ESRI.ArcGIS.esriSystem.esriLicenseProductCode.esriLicenseProductCodeArcServer)
        ElseIf AoInit.IsProductCodeAvailable(ESRI.ArcGIS.esriSystem.esriLicenseProductCode.esriLicenseProductCodeEngine) = ESRI.ArcGIS.esriSystem.esriLicenseStatus.esriLicenseAvailable Then
            AoInit.Initialize(ESRI.ArcGIS.esriSystem.esriLicenseProductCode.esriLicenseProductCodeEngine)
        ElseIf AoInit.IsProductCodeAvailable(ESRI.ArcGIS.esriSystem.esriLicenseProductCode.esriLicenseProductCodeArcInfo) = ESRI.ArcGIS.esriSystem.esriLicenseStatus.esriLicenseAvailable Then
            AoInit.Initialize(ESRI.ArcGIS.esriSystem.esriLicenseProductCode.esriLicenseProductCodeArcInfo)
        ElseIf AoInit.IsProductCodeAvailable(ESRI.ArcGIS.esriSystem.esriLicenseProductCode.esriLicenseProductCodeArcEditor) = ESRI.ArcGIS.esriSystem.esriLicenseStatus.esriLicenseAvailable Then
            AoInit.Initialize(ESRI.ArcGIS.esriSystem.esriLicenseProductCode.esriLicenseProductCodeArcEditor)
        End If
    End Sub
RuchiraWelikala
With ArcGIS10 you need the Engine license to use mapcontrols.  It's something everyone is complaining about.  There are some ways around it.
http://forums.arcgis.com/threads/22020-Migrating-from-9.3.1-to-10-may-be-impossible-if-you-use-mapco...
cheers,
